for the “item types” it seems ok to me.
for the options I wonder why
ON = ok
OFF = Alarm
shouldnt that be vice versa?
also for flood alarm OFF = Closed ? closed seems odd?
ON = ok
OFF = Alarm
Yes - I’ve just swapped them, thanks.
This is cut and paste error - it says flood and ok.
sorry another question about the fibaro flood sensor…
when I just “Tilt” the sensor (which is some kind of tamper alarm for fibaro)
also “sensor_flood” gets updated to ON… any way I can influence that?
For “Tilt only” and not “water” I would like to send “alarm_general” only.
Tilt only log:
12:25:12.205 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 10 10 07 9C 02 10 00 FF 00 00 80
12:25:12.216 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:25:12.218 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 10 10 07 9C 02 10 00 FF 00 00 80
12:25:12.219 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 10 10 07 9C 02 10 00 FF 00 00 80
12:25:12.221 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=10 10 07 9C 02 10 00 FF 00 00
12:25:12.222 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 16: Application Command Request (ALIVE:DONE)
12:25:12.223 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 16: Incoming command class SENSOR_ALARM
12:25:12.224 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 16: Received Sensor Alarm Request
12:25:12.225 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 16: Alarm Report: Source=16, Type=General(0), Value=255
12:25:12.225 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmSensorValueEvent
12:25:12.226 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 16: Got an event from Z-Wave network: ZWaveAlarmSensorValueEvent
12:25:12.227 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 16: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_ALARM, value = 255
12:25:12.227 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:device:15348538564:node16:alarm_general to ON
12:25:12.229 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:device:15348538564:node16:sensor_flood to ON
It looks from the two logs that the device is sending exactly the same information for both conditions - if so, there’s no way to distinguish between the two conditions…
11:18:39.417 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 00 10 07 9C 02 10 00 FF 00 00 90
mhh I thought
flood thats the log when “watering” the sensor
11:18:40.200 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 16: Alarm Report: Source=16, Type=Flood(5), Value=255
tilt when only tilting it:
however both Types always result in updating both devices…
Ok - you’re right. I just looked at the first alarm in the log that you said was a flood alarm - I didn’t realised you’d triggered both alarms in that log so missed the one further down.
My Doorbell sensor seems to no longer work since upgrading to the latest build (that required everything to be setup again). That node is showing up, but as unknown. Here’s a couple of log messages:
18:13:00.705 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:home:node14' to inbox.
18:13:00.706 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:home:node14' has been added.```
Maybe the device information isn’t being updated in the properties if you accept the device before it’s completed initialisation. I’d suggest to remove it, let it complete initialisation so that it has a name, and then add it.
I’ll take a look at this since this obviously should be handled…
Its showing this even after I remove it and it’s be rediscovered (sitting in the inbox). I’ve tried waking it up, but that doesn’t seem to make a difference. Any other suggestions?
Please note that for the latest binding I made some changes to the channel definitions to hopefully fix an issue differentiating between different alarms etc.
This will likely mean that for devices that have channels with alarms, meters, set points etc, they will likely need to be deleted and re-added so they pick up the new definitions.
Chris
If there’s nothing in the log showing the device waking, then I’m not sure… The update shouldn’t have affected it’s configuration - it was mainly how the thing type and name are handled which is outside of the protocol layers.
If it’s close enough to the controller that it is in direct communications (eg within let’s say 59 ft) and waking it doesn’t help then it might need to be re included (which would be strange). Otherwise make sure it’s close enough so that the controller can hear it directly…
Dear @chris,
i have a problem, that i can’t save Configuration parameter 5 of my DSB05 4 in One MultiSensor. I can select “send sensor binary report”, click on save an have 2 times the entry in the log:
11:48:18.413 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:b172f74e:node2’ has been updated.
11:48:18.471 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:b172f74e:node2’ has been updated.
But i don’t works, checking the setup after the wake up time the entry ist lost in HABmin:
Could you please check whats going wrong?
Regards
Heiko
Any chance of a debug log please ?
@shorty707 please let me know if the latest binding correctly differentiates between flood and tilt (note that you’ll need to delete and add the thing in again to pick up the changed config).
Thanks. I managed to get it working again (finally). I ended up restarting OH, and then went right beside my controller and woke it up.
No problem Due my Fibaro FIB_FGMS-001 Multisensor lost their luminance with the latest snapshot i’ll setup from the scratch with only Z-Wave devices and log:set debug org.openhab.binding.zwave.
I have a number of Fibaro FGMS001 motion sensors, that with the latest binding show up as Unknown Devices the database shows these are complete am i missing something fundamental here?
I removed and then re-added the things for these, after which they were recognised properly.
the only complication here might be that my z-stick is a secondary controller for my zwave network, so i am not including/excluding from openhab
You shouldn’t need to include again, however if you are using a secondary controller, then you will need the device to be close enough to the controller that it can talk directly (ie not routed). You will then need to manually wake the device up as the wakeup class will presumably be configured to communicate with your other controller.
