I have a strange behaviour in my oh-stepper-card and oh-stepper-item widgets. Every time I press the plus button the item changes to the max value. After that the minus button works as exspected and changes the item in the steps given in widget configuration.
Does anyone had this behaviour?
Does anyone have a guess how to resolve this?
What command actually gets sent to the Item? What does the Item state do in response? Check your events.log (The binding/device may have an influence here)
Okay, that’s good.
We can see the Item had a valid state before you started (22 °C) but that the widget has sent an inappropriate command to the Item. Just 25, not 25 °C.
Looks like a widget bug.
I don’t know enough about the widget to say if min/max/step should be defined with or without units, probably without, but wonder if there is a UoM connection. Try with none at all specified, see if the defaults work.
I think the stepper widget has a unit parameter, maybe you just need to configure that.
Alright, so maybe the widget just messes up its maths when it encounters a state with units that it didn’t expect. Try again with additional param unit: "°C"
