Why?
2020-01-21 18:46:23.589 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'common.rules', using it anyway:
The constructor Boolean(boolean) is deprecated
common.rules:
var systemStarted = new Boolean(false)
var mqttStarted = new Boolean(false)
rule "when system started"
System started
if(! systemStarted){
systemStarted = true
if(! mqttStarted) {SYS_MQTT_Started.postUpdate(OFF)}
rule "Monitor MQTT action addon"
Time cron "0/30 * * * * ?"
if(! mqttStarted){
try {
publish("localmqtt", "RPI", "ping mqtt from OH")
finally {
mqttStarted = true
SYS_MQTT_Started.postUpdate(ON)
publish("localmqtt", "Reseting_omega", "restart_all_omega_relays_module")
rule "System start complete (push notification)"
Item SYS_StartComplete changed to ON
SYS_Notification.sendCommand('Open HAB is actually started' + ';0;16;1;;;;')
