The model of zwave:serial_zstick:{thingnumber} is inconsistent
after upgrading to OH 3.0.1 I get something new after reboot:
2021-01-28 21:49:34.397 [WARN ] [core.thing.internal.ThingManagerImpl] - The model of zwave:serial_zstick:be5a3a02 is inconsistent [thing.getHandler().getThing() != thing]
2021-01-28 21:50:34.354 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 42: Error in initialization thread
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@a294ee[Not completed, task = org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter@1a014be] rejected from java.util.concurrent.ThreadPoolExecutor@3c3bbb[Shutting down, pool size = 14, active threads = 14, queued tasks = 0, completed tasks = 17]
	at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2055) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:825) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1355) ~[?:?]
	at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140) ~[?:?]
	at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.sendTransactionAsync(ZWaveTransactionManager.java:1191) ~[bundleFile:?]
	at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.sendTransaction(ZWaveTransactionManager.java:1203) ~[bundleFile:?]
	at org.openhab.binding.zwave.internal.protocol.ZWaveController.sendTransaction(ZWaveController.java:532) ~[bundleFile:?]
	at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:291) ~[bundleFile:?]
	at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:264) ~[bundleFile:?]
	at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.doInitialStages(ZWaveNodeInitStageAdvancer.java:378) ~[bundleFile:?]
	at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer$1.run(ZWaveNodeInitStageAdvancer.java:188) [bundleFile:?]
2021-01-30 04:53:29.720 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 39: Unsupported command class 0x1
2021-01-30 04:53:29.759 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 39: Unsupported command class 0x1
and after a while I got
2021-01-30 15:45:36.334 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
2021-01-30 15:51:15.473 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
2021-01-30 16:01:12.974 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
2021-01-30 16:18:09.647 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
2021-01-30 16:57:34.847 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
2021-01-30 16:58:31.532 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
I read about it in another topic here:
HELP! Someone Hacked my system? Lights and other turning on and off randomly. OH3 Snapshot - #12 by Kamil_Matuszczak
I don’t think I got hacked, I don’t have anyone else turning on/off my lights but…is this something that has to do with zwave or anything to pay attention at?
thanks!
