Hi guys,
I´m helping a friend out who runs a (food and completely legal!!!)-mushroom plant growing it on used coffee gounds. While the mushrooms grow, they produce CO2 and heat, that has to be removed out of the cellar. There he needs accurate temperature, moist and Co2 Info, and has to react on that data. Instead of a timeclock !! steering a ventilator a built an nodemcu based (easyESP) multisensor that measures temperature, moist and Co2 and publishes it every via mqtt to my Raspi2 running OH2 with mosquitto as mqtt broker… horray… that works.
Now that that my oh2 has the values I would love to store and display the data via rrdj4 ? and react to some values by predefined rules.
For instance if CO2 level rises above 1500 ppm start the vent for 10 minutes.
If temperatures goes above 20 C start air condition for 20minutes.
For steering air cond and vent I use sonoff switches flashed with tasmota. (also works)
I´m looking for examples that I can use or alter for that applications. And of course I would then write a doku story for best practise.
Ideas?
There are plenty of code examples in the forum and the tutos.
I will not write code for you. You need to do that yourself.
If it doesn’t work and you can’t figure out why, then by all means ask for help.
I’ll write a short rule to point you in the right direction
Do your items work in OH?
Do you receive updated values through mqtt and can you command the air con sonoffs from openHAB via mqtt?
I’ll assume that the answer is Yes
Then create a *.rules file in the rules folder
var Timer timer
rule "Too much CO2"
Item_CO2_Sensor received update
if (Item_CO2_Sensor.value > 1500) {
if (timer === null) {
Item_Vent.sendCommand(ON) //turn on the vent
timer = createTimer(now.plusMinutes(10), [ | //start and create the timer
Item_Vent.sendCommand(OFF) //end of timer action
timer = null //reset the timer
Merci Vincent,
Yep, the item allready work fine within OH. Thank you for the code! That gives me a solid base to start working. I will try my best and will report the status thereafter! Apparantly I´m measuring CO2 with an MH-Z19 and was impressed by the accurat results.
bye for now!
Hi all, meanwhile the MH-z19 is working fine on an NODEMCU running the lastest easy ESP firmware.
I never had input values running into openhab, so first I´ve set up an mqtt broker (mosquito) on OH2 and an items file and a sitemap to visualize the incoming CO2 values. But somehow I expirience troubles:
Quite desperate…
ohbroker is running according the log…
altered the sitemap to:
[01:33:23] openhabian@openHABianPi:/etc/openhab2/sitemaps$ more co2.sitemap
sitemap co2 label=“My home automation” {
Frame label="Demo" {
Text item=co2 label="Konzentration [%.1f PPM]"
and the co2.items to:
[01:36:24] openhabian@openHABianPi:/etc/openhab2/items$ more co2.items
Number co2 “Temperatur [%.0f °C]” (livingRoom) [“CurrentTemperature”] {mqtt="<[ohbroker://co2_esp/gas/PPM/:state:default]" }
[01:36:33] openhabian@openHABianPi:/etc/openhab2/items$
still no value is displayed… hmpf going to have some sleep now… ;-((
This morning I found that the version of EASY ESP 8.7.2018 had a problem with the generation of the JSON output which now is fixed. I´m now trying with the current version.
[JSON] Fixed broken JSON output on /json URL
As you said I subscribed to all # and the ESP nicly sends data to the client.
Problem is surely the interpretation of the JSON Path.
Can you also please give me a hint, how I eventually can visualize the data via rrdj4?
thanks and if you send a mail to robert@kotal.at with your adress I would be glad to send you some Mozartkugeln next week when I´m home. This saved me a lot of time.
Yep! success… but still no value in the frontend?? and sometimes strange messages in the log:
see:
=> /var/log/openhab2/openhab.log <==
2018-07-08 18:13:09.164 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value ‘790.00’ of item co2 with format ‘%0.f PPM’: {}
java.util.UnknownFormatConversionException: Conversion = ‘0’
at java.util.Formatter.checkText(Formatter.java:2579) [?:?]
at java.util.Formatter.parse(Formatter.java:2565) [?:?]
at java.util.Formatter.format(Formatter.java:2501) [?:?]
at java.util.Formatter.format(Formatter.java:2455) [?:?]
at java.lang.String.format(String.java:2940) [?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.format(DecimalType.java:77) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:372) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:118) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.TextRenderer.renderWidget(TextRenderer.java:42) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:172) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:137) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:158) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:100) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:159) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
2018-07-08 18:13:24.555 [vent.ItemStateChangedEvent] - co2 changed from 790.00 to 789.00
2018-07-08 18:13:26.544 [vent.ItemStateChangedEvent] - co2 changed from 789.00 to 788.00
2018-07-08 18:13:28.544 [vent.ItemStateChangedEvent] - co2 changed from 788.00 to 787.00
2018-07-08 18:13:30.541 [vent.ItemStateChangedEvent] - co2 changed from 787.00 to 785.00
2018-07-08 18:13:32.550 [vent.ItemStateChangedEvent] - co2 changed from 785.00 to 783.00
2018-07-08 18:13:34.553 [vent.ItemStateChangedEvent] - co2 changed from 783.00 to 781.00
2018-07-08 18:13:36.543 [vent.ItemStateChangedEvent] - co2 changed from 781.00 to 779.00
2018-07-08 18:13:38.543 [vent.ItemStateChangedEvent] - co2 changed from 779.00 to 778.00
2018-07-08 18:13:40.543 [vent.ItemStateChangedEvent] - co2 changed from 778.00 to 777.00
