Hello guys,
maybe somebody can help me out here because im going crazy. I have openhab 2 running on an ubuntu pc. all my other bindigs are working fine i have max! and Mqtt… i have been trying to get them´milight binding 2.0 working since 2 weeks , i configured it via the paper ui by adding the bridge manually because the discovery was not working. After adding the bridge manually (entering the ip adress) it apears in the inbox. other items also apear in the inbox
Afterwards i created the things via the paper ui:
and then finally the items:
whatever i click whatever i do nothing happens:
the binding does nothing . I am new to openhab and my knoledge on this still needs to grow but however i managed to tail the log :
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.receiveTypedEv ent(ThingLinkManager.java:304)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.receiveTypedEv ent(ThingLinkManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at org.eclipse.smarthome.core.events.AbstractTypedEventSubscriber.receiv e(AbstractTypedEventSubscriber.java:50)[98:org.eclipse.smarthome.core:0.9.0.b3]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OS GiEventManager.java:192)[98:org.eclipse.smarthome.core:0.9.0.b3]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OS GiEventManager.java:1)[98:org.eclipse.smarthome.core:0.9.0.b3]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.ca ll(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.b3]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor. java:1142)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor .java:617)[:1.8.0_131]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
2017-05-08 21:31:52.686 [ItemChannelLinkAddedEvent ] - Link 'milight_rgbLed_ec35 ce8a_9_discomode-milight:rgbLed:ec35ce8a:9:discomode' has been added.
2017-05-08 21:31:52.690 [ItemAddedEvent ] - Item 'milight_rgbLed_ec35 ce8a_9_lednightmode' has been added.
2017-05-08 21:31:52.693 [ItemAddedEvent ] - Item 'milight_rgbLed_ec35 ce8a_9_ledbrightness' has been added.
2017-05-08 21:31:52.693 [hingStatusInfoChangedEvent] - 'milight:rgbLed:ec35ce8a: 9' changed from UNINITIALIZED to INITIALIZING
2017-05-08 21:31:52.697 [ItemAddedEvent ] - Item 'milight_rgbLed_ec35 ce8a_9_ledcolor' has been added.
2017-05-08 21:31:52.701 [ItemAddedEvent ] - Item 'milight_rgbLed_ec35 ce8a_9_discospeed' has been added.
2017-05-08 21:31:52.702 [ItemAddedEvent ] - Item 'milight_rgbLed_ec35 ce8a_9_discomode' has been added.
2017-05-08 21:31:52.704 [InboxRemovedEvent ] - Discovery Result with UID 'milight:rgbLed:ec35ce8a:9' has been removed.
2017-05-08 21:31:52.706 [ThingAddedEvent ] - Thing 'milight:rgbLed:ec3 5ce8a:9' has been added.
2017-05-08 21:31:52.805 [hingStatusInfoChangedEvent] - 'milight:rgbLed:ec35ce8a: 9' changed from INITIALIZING to ONLINE
2017-05-08 21:36:02.995 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:02.997 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from NULL to ON
2017-05-08 21:36:04.524 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:04.526 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:05.336 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:05.338 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:06.005 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:06.007 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:06.607 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:06.611 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:07.141 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:07.144 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:07.654 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:07.657 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:08.087 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:08.090 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:08.493 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:08.496 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:08.855 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:08.857 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:09.166 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:09.168 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:09.461 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:09.465 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:09.742 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:09.744 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:10.724 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:10.726 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from NULL to 100
2017-05-08 21:36:11.042 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:11.044 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:11.241 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:11.243 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:11.458 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:11.460 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:11.659 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:11.662 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:11.804 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:11.808 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:11.948 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:11.951 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:12.107 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:12.109 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:12.521 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:12.525 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:12.682 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:12.685 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:12.826 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:12.828 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:13.113 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:13.115 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:13.257 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:13.260 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:14.683 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 288,100,100
2017-05-08 21:36:14.686 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from NULL to 288,100,100
2017-05-08 21:36:14.983 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 226,100,100
2017-05-08 21:36:14.985 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 288,100,100 to 226,100,100
2017-05-08 21:36:15.511 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 72,100,100
2017-05-08 21:36:15.512 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 226,100,100 to 72,100,100
2017-05-08 21:36:15.925 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 42,100,100
2017-05-08 21:36:15.928 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 72,100,100 to 42,100,100
2017-05-08 21:36:16.255 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 168,100,100
2017-05-08 21:36:16.257 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 42,100,100 to 168,100,100
2017-05-08 21:36:16.570 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 279,100,100
2017-05-08 21:36:16.572 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 168,100,100 to 279,100,100
2017-05-08 21:36:17.038 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 135,100,100
2017-05-08 21:36:17.040 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 279,100,100 to 135,100,100
2017-05-08 21:36:17.358 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,100,100
2017-05-08 21:36:17.362 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 135,100,100 to 132,100,100
2017-05-08 21:36:17.911 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,100,43
2017-05-08 21:36:17.914 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,100,100 to 132,100,43
2017-05-08 21:36:18.571 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,100,27
2017-05-08 21:36:18.573 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,100,43 to 132,100,27
2017-05-08 21:36:19.211 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,100,55
2017-05-08 21:36:19.213 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,100,27 to 132,100,55
2017-05-08 21:36:19.821 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,58,55
2017-05-08 21:36:19.822 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,100,55 to 132,58,55
2017-05-08 21:36:20.193 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,31,55
2017-05-08 21:36:20.195 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,58,55 to 132,31,55
2017-05-08 21:36:20.693 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,19,55
2017-05-08 21:36:20.696 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,31,55 to 132,19,55
2017-05-08 21:36:21.223 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledcolor' received command 132,71,55
2017-05-08 21:36:21.224 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_discospeed' received command 151
2017-05-08 21:36:21.228 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledcolor changed from 132,19,55 to 132,71,55
2017-05-08 21:36:21.230 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_discospeed changed from NULL to 151
2017-05-08 21:36:21.669 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_discospeed' received command 199
2017-05-08 21:36:21.672 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_discospeed changed from 151 to 199
2017-05-08 21:36:22.175 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_discospeed' received command 118
2017-05-08 21:36:22.178 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_discospeed changed from 199 to 118
2017-05-08 21:36:22.250 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_discospeed' received command 116
2017-05-08 21:36:22.252 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_discospeed changed from 118 to 116
2017-05-08 21:36:23.596 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:23.598 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:24.076 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:24.079 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:24.516 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:24.519 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:24.811 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:24.813 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:25.088 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:25.090 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:25.269 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:25.272 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:25.596 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:25.599 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:25.765 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:25.767 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:25.948 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:25.950 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:26.076 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:26.078 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:26.366 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:26.369 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:26.687 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:26.690 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:26.860 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:26.862 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:27.020 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:27.022 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:27.338 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:27.339 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:27.487 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command ON
2017-05-08 21:36:27.489 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from OFF to ON
2017-05-08 21:36:27.653 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_lednightmode' received command OFF
2017-05-08 21:36:27.656 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_lednightmode changed from ON to OFF
2017-05-08 21:36:28.095 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:28.099 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:28.457 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:28.459 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:28.793 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:28.797 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:29.128 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:29.130 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
2017-05-08 21:36:29.394 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command OFF
2017-05-08 21:36:29.397 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 100 to 0
2017-05-08 21:36:29.618 [ItemCommandEvent ] - Item 'milight_rgbLed_ec35ce8a_9_ledbrightness' received command ON
2017-05-08 21:36:29.620 [ItemStateChangedEvent ] - milight_rgbLed_ec35ce8a_9_ledbrightness changed from 0 to 100
another thing that i tried is to enter the ibox mac under thing id . if i do that however the bridge doesn’t appear as online anymore.
I am using the IBOX2 bridge and it is working with the app. the bulbs that i am using are RGBWW
http://www.gearbest.com/smart-lighting/pp_435807.html
Another funny thing that happens is the following : i tried sniffing the trafic on the OpenHab server when clicking arround on the switches for brightness .
It appears that from the openhab pc some data is being sent to the bridge but it appears that it doesnt reach it.
Please take a look in the following picture (192.168.0.45 is the openhab machine and 192.168.0.81 is the bridge)
and finally i am attaching the config from the web interface of the bridge:
Nothing happens also if i modify the protocol from tcp to udp in the network parameter setting, i also tried that
maybe there is an incompatibility issue between my harware (bulbs, bridge) and the binding.
If somebody can tell me whats wrong i would really apreciate it.
