first thanks for the great work with this binding, its amazing.
The only thing that i cant get to run is the disco mode. I read about the issues with the whitemode or the nightmode
but is there also a problem with the discomode?
Each time i send an number to my animation mode item, the only reaction from my bulbs is to reduce the brightness.
Hope anyone could help me, thanks for your answers!
Hi Ramasouto,
I have the same problem after update at 2.3.0 ⌠I tried to reload the 2.0 binding but whitemode doesnât work.
I read the ESP8266 bridge but I donât understand how can the whitemode be solved.
Can you share your solution?
Lorenzo
I ran this in karaf. This was right after I updated to 2.2. Iâm no computer wiz so Iâm not sure what negative effects this would have but it stopped the flood of milight updates in the log.
@David_Graeff it is possible use ONE Milight bridge to control 16 groups
âNote that you can assign an rgbw, rgbww, white and dimmer group to the same group number, effectively allowing 16 groups (4 rgbww, 4 rgbw, 4 white and 4 dimmer) per bridge.â
so could you update openhab bindings to support this? this is about milight bridge produced after July 2017
produces (auto discovery)10 inbox entries = 4 rgbw (zone1,zone2,zone3,zone4) + 4 rgbww (zone1,zone2,zone3,zone4) + 1 all zones rgbw + 1 all zones rgbww
Could I use 8 groups then?
You need to specify your bulb type because they expect different commands. Those two bulbs types still belong to group 1 to 4. Milight doesnât support a proper discovery, thatâs why you are presented with all possible types.
Somehow I am having troubles with the detection of the IBox1. It just wonât discover it and when adding it manually it gives me an error 500 in PaperUI. I made a post here. Can anyone give advice?
Nobody has problems with {channel=âmilight:rgbwLed:bridge:1:animation_speed_relativeâ,autoupdate=âfalseâ}
on rgbw strip
iâve checked several times for errors in my OH configuration and seems everything ok.
the issue is that in binding only decrease animation speed works, but it is impossible for me to increase it.
in Karaf consolle, in debug mode filtered on Milight binding, i discovered that no packet are sent to gateway only sending increase command on animation_speed_relative.
in all other strip functions everything works fine
thanks for any help
If I remember correctly, I had to âmanuallyâ search for the iBox/iBox 2 Bridge in OpenHab via PaperUI, then it would auto discover all of the zones after that.
When I manually added it, I had already configured my router to give it a static internal IP, so that OpenHAB would not have to look for it. So I entered that IP, then entered the MAC address of the Bridge as the âBridge IDâ. Bear in mind that this field requires no delimiter, so should just be a string of 12 characters with no colons.
Also, when manually adding, be sure to select the correct type of bridge. The iBox is the one that is a small dome with built in LED, while the older milight bridge is thinnish rectangular box with a label.
