Had a lot of work last week, so i couldn’t support. It’s great to see how this binding improves. Bad luck, that your recorder isn’t working for me. But maybe some pcap files can help you too?!
ibox int light.pcap.pdf (13.7 KB)
What did i do? I saw that your Color (iBox) doesnt support clean white - maybe because you dont know the right commands for that? So i switched a lot between clean white and red - i think you will get the right command
Please tell me, if you need more pcap files of certain actions…
Apart from that, the colors for rgbw leds are not what i would expect:
-> red seems a litte bit like pink
-> the more i move the slider to orage, the more pink it gets
-> yellow is something like purple
-> green is blue
-> now the slider stops working, and is only reacting if i start moving it from right to left
-> the more i move the slider to purple/pink, the more orange it gets
-> purple is yellow
-> blue isn’t changing anything at all, not moving to it from the left, nor from the right.
I dont know if you know, but inside the milight app, the colors have values:
red: 0
yellow: 50
green: 100
blue: something around 185
between that, there are the gradients from one color to another.
Here is another pcap file containing the traffic of going around the color wheel, ending with sliding up and down brightness and saturation - zone one, with rgbw leds:
colorwheel saturation brightness.pcap.pdf (51.9 KB)
I hope this helps! If you need something special, please let me know!
