I have an Android tablet on the wall and the display is always on. A page of UI 3 (3.4.2) is displayed on it. After some time, the widgets are no longer updated and you can no longer trigger commands. Switching to another page will make it work again.
Has anyone else observed this behavior and was able to fix it, or is there a way to switch pages automatically after a period of time?
This is a known issue that is common to the MainUI. Search the forums for “MainUI sse” and you should find many threads about loosing the UI connection to OH.
Thanks for the reply, unfortunately there doesn’t seem to be a real solution.
The only thing that seems to work is a LAN connection, which I can’t get on the tablet.
