When I start OpenHAB (2.5.11) I see this INFO in the log, but I fail to understand why:
2021-01-31 13:19:49.494 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'power.rules', using it anyway:
The value of the local variable DailyPowerProductionAPS is not used
It is used:
rule "Daily power production calculation APSystems"
Item ZonnepanelenWh_schuur changed
var DailyPowerProductionAPS = ZonnepanelenWh_schuur.deltaSince(now.withTimeAtStartOfDay)
//logInfo("Daily power production APS ", "DailyPowerProduction APS = " + DailyPowerProductionAPS)
if ( DailyPowerProductionAPS === null || DailyPowerProductionAPS == NULL) {
logInfo("Daily power production calculation APSystems", "DailyPowerProductionAPS = " + DailyPowerProductionAPS)
} else {
APSACLifetimeEnergyToday.postUpdate(DailyPowerProductionAPS as Number)
Normally VScode would also display this error if it’s true, but there is no error in VScode.
I use the same code for my other solar panels and that doesn’t give me an error:
rule "Daily power production calculation SolarEDGE"
Time cron "0 0/1 * 1/1 * ? *"
//Item SE7KACLifetimeEnergy changed //Every few sec is too much, changed to every minute
var DailyPowerProduction = SE7KACLifetimeEnergy.deltaSince(now.withTimeAtStartOfDay)
//logInfo("Daily power production", "DailyPowerProduction = " + DailyPowerProduction)
if ( DailyPowerProduction === null || DailyPowerProduction == NULL) {
logInfo("Daily power production calculation SolarEDGE", "DailyPowerProduction = " + DailyPowerProduction)
} else {
SE7KACLifetimeEnergyToday.postUpdate(DailyPowerProduction as Number)
