I have just noticed my startup openhabjs script is failing but just before I see the following error:
[nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘jdbc’
then after my script fails (see below). I’ve just updated to the latest 4.2.1 patch and I’m pretty sure this did used to work …
Failed to execute rule EV-Energy-startupComplete-d40eb4fb-80a2-48ee-9276-0f4d8e5c99f0: TypeError: Cannot get property "numericState" of null: TypeError: Cannot get property "numericState" of null
at <program> (energy_EV.js:14)
at _run (@openhab-globals.js:2)
at execute (@openhab-globals.js:2)
line: 14 is using persistence service to query historical values
rules.when().system().startupComplete().then(event => {
var daySoFar = Energy_EV_energy_interval.persistence.sumSince(new Date(new Date().setHours(0, 0, 0))).numericState //sum since midnight
if I re-save script it works fine… is this a timing issue, as it should execute after startup completed
thanks
It might be the case that jdbc isn’t yet loaded and online by the time run level 100 is reached.
If you set a timer to execute this say 10 seconds after the rule triggers does it work?
This is a really awkward way to do this. First of all you should be using time.ZonedDateTimes instead of JS Date. Being that, why create a new Date with a new Date? it’s redundant.
The “official” way to get midnight is time.toZDT(“00:00”).
thanks for the reply
a timer or sleep ok?
I just put a sleep after startup was executed
java.lang.Thread.sleep(8000) ; // wait 8 secs
This appears to fix it, I assume jdbc initialization isn’t somehow using Startup event, which is a bit frustrating.
and thanks updating the midnight reference as suggested.
I see if the logs the service I assume is ready about 8 seconds later
2024-08-10 09:22:53.595 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'jdbc'
2024-08-10 09:23:01.755 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
Long term a timer would be better. For testing a sleep is fine.
Just the opposite really. The start levels do not account for persistence being available. So run level 100 is reached whether or not persistence is ready.
Should work, but be aware that this means that the rule will run 8 seconds later (based on those logs), not that persistence is going to be available sooner.
since last update I have now changed to 12secs …
this is not a great way to manage my code.
is there no better way if I need to retrieve from persistence after startup
If the add-on is not available then there really isn’t anything else you can do.
Though there has been some work to include persistence in the startup process so it contributes to the runlevel now and the PR you linked to above has been merged. Are you still on 4.1? Is it still a problem in the latest 4.3 milestone?
I’m currently on openHAB 4.2.3 ( on Ubuntu repo package), and yes it appears to be still an issue, although increasing the “sleep” or wait time does work for now.
