There is no queryable persistence service registered with the id 'null'
after upgrading from OH2 to OH3 some months back, I get always the following two lines - once per minute:
2023-07-05 17:00:00.080 [WARN ] [nce.extensions.PersistenceExtensions] - There is no default persistence service configured!
2023-07-05 17:00:00.081 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'null'
Not a real issue but annoying and apparently something is not working as expected… :slight_smile:
My persistence (JDBC) itself seems to be working well though - as before in OH2.
Any idea where to look?!
Thanks.
Hmmm… könnte es sein, dass man in der runtime.cfg einfach als default-Service jdbc eintragen muss und “that’s it”?! :slight_smile:
Auf Englisch bitte :wink:
If you have properly configured the default persistence in the OH3 MainUI, then you shouldn’t have to enter it into the runtime.cfg config.
Go to Settings → Persistence and make sure you have selected a default service from there.
