Therefore ignoring it: [162,3]: no viable alternative at input 'Contact'
Sitemap:
Contact item=BRClosetDoorOpenClose label=“Closet OpenClose [%s]”
Item:
Device: Monoprice zwave door window sensor
This this is confusing.
If i set it as a switch in the sitemap it loads; contact, i get that error in the subject…no viable alternative
If i set them both to switch, they load.
I can set the sitemap to text and that works too.
Other weird thing is the alarm on this thing and the open/close work the same way. when it opens, they both trip; when it closes, they both get set.
Wrong item definition, must be:
Switch BRClosetDoorOpenClose “Closet OpenClose [%s]” { channel=“zwave:device:yxyxyxyxyxy:nodexx:channel_name” }
See http://docs.openhab.org/configuration/items.html and http://docs.openhab.org/addons/bindings/zwave/readme.html
Edit: btw, I don’t see a monoprice door/window sensor in the zwave database:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list
