Hi everybody,
I migrated from OH 2.5.11 to OH 3.0.0 one week ago.
Everything working fine so far.
But today I had the issue that some (and not all) of my cron rules are firing double:
Here’s an example of one of the cron rules:
rule “Buerotemperatur auf normale Temperatur morgens abhaengig von Praesenz”
Time cron “0 5 6 ? * SUN,MON,TUE,WED,THU,FRI,SAT”
In the event.log I can see, that the rule was firing one minute to early (6:04) and again at the correct time (6:05):
2021-01-05 06:04:02.466 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘i_mqtt_thermostat8_Targettemperature’ received command 23.0
2021-01-05 06:04:02.479 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘i_mqtt_thermostat8_Targettemperature’ predicted to become 23.0
2021-01-05 06:04:02.482 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘i_mqtt_thermostat8_Targettemperature’ changed from 20.0 to 23.0
2021-01-05 06:05:00.457 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘i_mqtt_thermostat8_Targettemperature’ received command 23.0
2021-01-05 06:05:00.458 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘i_mqtt_thermostat8_Targettemperature’ predicted to become 23.0
The rule was working fine in version 2.5.x for over an year and in OH 3.0.0 for more than a week. Other cron rules are firing once only
Time on the Raspberry Pi (where OH is running) is ntp synchronized.
Any Idea, what can go wrong here?
