You’d have to look at the scripts that install it then to see where it’s installed from. I didn’t think I installed it separately on my one openHABian machine but maybe I did.
really only thing I found is this
firemotd_setup() {
FAILED=0
echo -n "$(timestamp) [openHABian] Downloading and setting up FireMotD... "
cond_redirect apt-get update
cond_redirect apt-get -y install bc sysstat jq moreutils
and
Install bc + sysstat - needed for FireMotD
which are only support packages required by firemotd, so i believe it’s already compiled and part of the image file, so … how to remove it?
that routine you already found contains everything you need to know, just read the rest
ah, yes, it was wrapped around the corner
firemotd gone, thanks
