The answer is you send an empty string
Not really - this will set the parameter to an empty string - it won’t remove it.
Well in any case, sending an empty string removed the values. Which is exactly what I needed.
You’re so literal Chris
All good, values/parameters, different but same to a mug like me.
Absolutely. You can assign anything to new_value
, not just integers.
new_value = outside_lux.state
should work just fine.
You can also configure Things using jython. This may also work for unmanaged Things, but I haven’t tried it.
try:
from org.openhab.core.thing import ThingUID
except:
from org.eclipse.smarthome.core.thing import ThingUID
then from within a rule, for example:
z_thing = things.get(ThingUID("zwave:device:741b4f3b:node10"))
z_thing.getConfiguration().put("config_6_1", someValue)
Unmanaged Things are not configurable. BTW, I have a core.things module nearly ready to commit.
Good to know.
Looking forward to it.
Hi @DavidR,
thanks for the code!
Do you have to do something so that the thing is updating (it is a zwave sensor)?
I can set the config but there is no reaction. If I do it via Paper UI it seems that it is reacting.
Whether I do it by rule or PaperUI, it does the same. Have you tried turning on debug logging for Z-Wave? That may give some clues.
Hi Scott,
sorry to pull up such an old thread. Did you ever commit the core.things module? I’m looking for a jython example of how to create a thing and it’s channels. Would this module of yours solve this need?
Not yet, but it’s coming. I merged a number PRs last night, but there is a lot more to go.
OpenHAB Community,
I stumbled upon this thread looking for a “native” OpenHAB solution to being able to configure a Thing configuration parameter as part of a Rule.
The solution that I currently have it to use ZWaveJSUI and Zigbee2MQTT, and then you can literally map the MQTT topic to a channel and then to an Item.
So for example, I have an Inovelli LZW36 light/fan combo zwave switch connected to ZwaveJSUI, with this Generic MQTT Thing configuration:
Thing mqtt:topic:zwave01-nodeID_15 "F1_GuestRoom_Wall_Switch" (mqtt:broker:8fd56e1f3c)
Channels:
Type dimmer : light_dimmer
transformationPattern="JSONPATH:$.value",
stateTopic="zwave01/nodeID_15/switch_multilevel/endpoint_1/currentValue",
commandTopic="zwave01/nodeID_15/switch_multilevel/endpoint_1/targetValue/set",
min=0,
max=100,
step=5
Type dimmer : fan_dimmer
stateTopic="zwave01/nodeID_15/switch_multilevel/endpoint_2/currentValue",
commandTopic="zwave01/nodeID_15/switch_multilevel/endpoint_2/targetValue/set",
min=0,
max=100,
step=5
Type number : kWh [stateTopic="zwave01/nodeID_15/meter/endpoint_0/value/65537", transformationPattern="JSONPATH:$.value"]
Type number : watts [stateTopic="zwave01/nodeID_15/meter/endpoint_0/value/66049", transformationPattern="JSONPATH:$.value"]
Type number : light-led-color
stateTopic="zwave01/nodeID_15/configuration/endpoint_0/Light_LED_Indicator_Color",
commandTopic="zwave01/nodeID_15/configuration/endpoint_0/Light_LED_Indicator_Color/set"
This is my Item configuration:
// F1_GuestRoom
Group gF1_GuestRoom_Wall_Switch "Wall Switch" <light> (F1_GuestRoom) ["Equipment","WallSwitch"]
Dimmer F1_GuestRoom_Light "Guest Room Light [%d]" <light> (gF1_GuestRoom_Wall_Switch) ["Lighting","Switchable","Point"] {ga="Light", channel="mqtt:topic:zwave01-nodeID_15:light_dimmer"}
Dimmer F1_GuestRoom_Fan "Guest Room Fan [%d]" <fan_ceiling> (gF1_GuestRoom_Wall_Switch) ["Switchable","Point"] {ga="Fan" [ speeds="0=off:zero,33=low:one,66=medium:two,99=high:three", lang="en", ordered=true ], channel="mqtt:topic:zwave01-nodeID_15:fan_dimmer"}
Number:Energy F1_GuestRoom_kWh "Fan/Light Power Consumption [%.1f kWh]" <Energy> (gF1_GuestRoom_Wall_Switch) ["Energy","Point","Measurement"] {unit="kWh",channel="mqtt:topic:zwave01-nodeID_15:kWh"}
Number:Power F1_GuestRoom_watts "Fan/Light Wattage [%.1f W]" <Energy> (gF1_GuestRoom_Wall_Switch) ["Energy","Point","Measurement"] {unit="W",channel="mqtt:topic:zwave01-nodeID_15:watts"}
Number F1_GuestRoom_LightLEDColor "Guest Room Light Color [%d]" <light> (gF1_GuestRoom_Wall_Switch) ["Point"] {channel="mqtt:topic:zwave01-nodeID_15:light-led-color"}
As you can see, you can map configuration endpoints just as easily as switch endpoints.
