I am working on porting the chamberlain myq binding to 2.5 and I am getting a no binding found that supports creating a thing of type error.
Cannot create thing. No binding found that supports creating a thing of type 'chamberlainmyq:MyQGateway'.
I added the id to my thing xml file.
<bridge-type id="MyQGateway">
and the ChamberlainMyQHandlerFactory has the supportsThingType method overriden:
public static final String BINDING_ID = "chamberlainmyq";
public static final Set<ThingTypeUID> DISCOVERABLE_DEVICE_TYPES_UIDS = Collections.unmodifiableSet(
Stream.of(THING_TYPE_DOOR_OPENER, THING_TYPE_LIGHT).collect(Collectors.toSet()));
private static final Set<ThingTypeUID> SUPPORTED_THING_TYPES_UIDS = Collections.singleton(THING_TYPE_BRIDGE);
@Override
public boolean supportsThingType(ThingTypeUID thingTypeUID) {
return SUPPORTED_THING_TYPES_UIDS.contains(thingTypeUID)
|| DISCOVERABLE_DEVICE_TYPES_UIDS.contains(thingTypeUID);
// bridge
public static final ThingTypeUID THING_TYPE_BRIDGE = new ThingTypeUID(BINDING_ID, "MyQGateway");
// List of all Thing Type UIDs
public static final ThingTypeUID THING_TYPE_DOOR_OPENER = new ThingTypeUID(BINDING_ID, "MyQDoorOpener");
public static final ThingTypeUID THING_TYPE_LIGHT = new ThingTypeUID(BINDING_ID, "MyQLight");
I am unsure what the issue is, I looked at https://www.openhab.org/docs/developer/bindings/#the-thinghandlerfactory and everything looks correct. This code use to work with 2.4 but now it won’t work with 2.5M4. Any help would be greatly appreciated.
Thank you,
Scott
MyQGateway.xml (1.9 KB)
ChamberlainMyQBindingConstants.txt (3.0 KB)
ChamberlainMyQHandlerFactory.txt (3.1 KB)
