Thanks Mark, managed to get it and find the configuration parameters.
Do you know how I would delete a configuration parameter? for instance user_code_4:1111 is the code for user 4. Lets say I wanted to delete the code for user 4
I’ve not done deletions before, but I suspect you’ll need to update the thing using the PUT http method. Note that this can be a bit dangerous if you don’t get it exactly right.
Ill have to have a play around. The intention is to build a Widget or a Sitemap that will allow code entry to bypass the Habmin or PaperUI via Binding method of code creation/deletion.
