I would like my “RFXCOM USB Transceiver”-thing that connects to a RFXCOM trx433e transceiver to pick up sensors that it detects and put them in the “inbox”. It used to do this (inbox was full of garage door opening commands captured) in an earlier OpenHAB-version (Dont remember which, but it was 4 or 3), but now it is not working.
If I connect the RFXCOM trx433e-unit to a Windows-machine and run RFXmngr and press a button on a NEXA MYCT-2120 it will happily inform me of a detection
2025-10-22 05:30:19:069= 0B110000005453230D010F70
Packettype = Lighting2
subtype = AC
Sequence nbr = 0
ID = 0545323 decimal:5526307
Unit = 13
Command = On
Signal level = 7 -64dBm
Edit: The RFXcom-thing works well with a hygrometer that transmits temp. and humidity (A Telldus F007TPH) and various contactors/relays (NEXA CMR-101 and NEXA MYCR-2300)
It might not be the course of your problem but that’s not how an rfxcom config should look like: Only enable the protocols you really need because you’ve got that specific hardware. The protocols overlap and quite a few don’t work in combination.
So this is mine:
Did another test: I pressed a button on the NEXA MYCT-2120 while observing the status LEDs on the RFXcom transceiver. At every button press, a yellow LED flashed on the RFXcom transceiver
The problem seem to have gone away now since I updated to openHAB 5.1.0 from 5.0.3. I now got the buttonpresses in my inbox.
Also, for my daily use Windows 7 computer, Firefox updates stopped at 115.32.0esr (the firefox browser im using for this post is at 145.0.1). It turned out that logs were not displayed at all in the old firefox. Asking for what webbrowser a user uses to access openHAB may be a good add to the basic info to ask for.
With a less ancient webbrowser the log viewer actually works and shows that OpenHAB indeed picks up my NEXA MYCT-2120.
