Yes in the meantime I checked about this and will fix the directorys in that file. It’s still looking into directory openhab2 and not openhab. Thanks for your help. This will make bug finding a lot easier again in the future.
But we are moving away from the main issue
@rlkoshak what should I look for in the logs?
Thats the startup of the logs:
2021-09-27 17:54:42.146 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2021-09-27 17:54:42.189 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '52.444301952493106,8.632566960606272'.
2021-09-27 17:54:42.193 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2021-09-27 17:55:20.014 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'caldav-command1' does not exist - ignoring it.
2021-09-27 17:55:20.021 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'weather1' does not exist - ignoring it.
2021-09-27 17:55:20.028 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'caldav-personal1' does not exist - ignoring it.
2021-09-27 17:55:20.032 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'fritzboxtr0641' does not exist - ignoring it.
2021-09-27 17:55:20.038 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'expire1' does not exist - ignoring it.
2021-09-27 17:55:20.073 [WARN ] [core.karaf.internal.FeatureInstaller] - The misc add-on 'mqttbroker' does not exist - ignoring it.
2021-09-27 17:55:20.102 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'homebuilder' does not exist - ignoring it.
2021-09-27 17:55:20.106 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'habmin' does not exist - ignoring it.
2021-09-27 17:55:20.111 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
2021-09-27 17:55:22.374 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'maschweg-items.items'
2021-09-27 17:55:26.277 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2021-09-27 17:55:27.444 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Maschweg.sitemap'
2021-09-27 17:55:28.084 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'Trockner_Verbrauch' could not be parsed correctly.
org.openhab.core.model.item.BindingConfigParseException: UID must have at least 4 segments.
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:86) ~[?:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:76) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:372) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:328) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:150) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1813) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
2021-09-27 17:55:28.333 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fritzbox.things'
2021-09-27 17:55:28.430 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'telegram.things'
2021-09-27 17:55:28.449 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2021-09-27 17:55:28.477 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'alexa.things'
2021-09-27 17:55:28.500 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'knx.things'
2021-09-27 17:55:32.800 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-09-27 17:55:33.181 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rollladen-alexa.rules'
2021-09-27 17:55:36.021 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Rolllaeden.rules'
2021-09-27 17:55:48.037 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'uebergangsfunktionen.rules'
2021-09-27 17:55:48.483 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'verschiedene-automatisierungen.rules'
2021-09-27 17:56:12.113 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'timegiver.rules'
2021-09-27 17:56:19.966 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'caldav-command1' does not exist - ignoring it.
2021-09-27 17:56:19.970 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'weather1' does not exist - ignoring it.
2021-09-27 17:56:19.976 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'caldav-personal1' does not exist - ignoring it.
2021-09-27 17:56:19.979 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'fritzboxtr0641' does not exist - ignoring it.
2021-09-27 17:56:19.984 [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'expire1' does not exist - ignoring it.
2021-09-27 17:56:20.010 [WARN ] [core.karaf.internal.FeatureInstaller] - The misc add-on 'mqttbroker' does not exist - ignoring it.
2021-09-27 17:56:20.033 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'homebuilder' does not exist - ignoring it.
2021-09-27 17:56:20.037 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'habmin' does not exist - ignoring it.
2021-09-27 17:56:20.040 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
2021-09-27 17:56:20.377 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'smarte-funktionen.rules'
2021-09-27 17:56:39.739 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'garagentorautomatik.rules'
2021-09-27 17:56:41.422 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'beleuchtung.rules'
2021-09-27 17:56:45.811 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'muellabfuhr.rules'
2021-09-27 17:56:47.453 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rumtesten.rules'
2021-09-27 17:56:48.020 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zeitstempel_und_stautswatch.rules'
2021-09-27 17:56:49.575 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'regenmenge.rules'
2021-09-27 17:56:56.372 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'wegmodus.rules'
2021-09-27 17:56:58.821 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'telegramaktionen.rules'
2021-09-27 17:56:59.150 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'heizung.rules'
2021-09-27 17:57:26.702 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lueftung.rules'
2021-09-27 17:57:34.442 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'gps.rules'
2021-09-27 17:57:35.972 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'benachrichtigungen.rules'
2021-09-27 17:58:00.438 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ausgesperrt.rules'
2021-09-27 17:58:01.354 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'alarmanlage.rules'
2021-09-27 17:58:17.264 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2021-09-27 17:58:19.042 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:sun:local' to inbox.
2021-09-27 17:58:19.111 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:moon:local' to inbox.
2021-09-27 17:58:20.315 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'ntp:ntp:local' to inbox.
2021-09-27 17:58:20.613 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'onkyo:TX-NR509:b4b00db2-700d-b2b9-c604-b20970b979c0' to inbox.
2021-09-27 17:58:23.141 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 90ad861c-6e27-49e5-a708-86fcea6dfc7f, base URL = http://localhost:8080)
2021-09-27 17:58:28.057 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2021-09-27 17:58:28.941 [ERROR] [ence.jdbc.internal.JdbcConfiguration] - Mandatory url parameter is missing in configuration!
2021-09-27 17:59:30.089 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-09-27 17:59:30.145 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.147 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.150 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Flur_Temperatur_Abgesenkt (Type=NumberItem, State=15, Label=Abgesenkte Temperatur Flur, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.155 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.158 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.160 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Flur_Temperatur_Komfort (Type=NumberItem, State=15, Label=Komfort Temperatur Flur, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.166 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.168 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.170 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Flur_Temperatur_Nacht (Type=NumberItem, State=15, Label=Nacht Temperatur Flur, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.173 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.175 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.191 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Flur_Temperatur_Weg (Type=NumberItem, State=15, Label=Weg Temperatur Flur, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.194 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.196 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.198 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Buero_Temperatur_Abgesenkt (Type=NumberItem, State=18, Label=Abgesenkte Temperatur Büro, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.250 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.252 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.254 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Buero_Temperatur_Komfort (Type=NumberItem, State=19, Label=Komfort Temperatur Büro, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.259 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.261 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.263 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Buero_Temperatur_Nacht (Type=NumberItem, State=18, Label=Nacht Temperatur Büro, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.275 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.277 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.278 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'EG_Buero_Temperatur_Weg (Type=NumberItem, State=17, Label=Weg Temperatur Büro, Category=temperature, Tags=[Temperature], Groups=[Temperaturspeicher])'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
2021-09-27 17:59:30.291 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'heizung-6' failed: Could not cast NULL to java.lang.Number; line 159, column 34, length 43 in heizung
2021-09-27 17:59:30.292 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'heizung-4' failed: Could not cast NULL to java.lang.Number; line 142, column 38, length 58 in heizung
2021-09-27 17:59:30.297 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'heizung-7' failed: Could not cast NULL to java.lang.Number; line 167, column 34, length 43 in heizung
2021-09-27 17:59:30.304 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'heizung-5' failed: Could not cast NULL to java.lang.Number; line 151, column 35, length 44 in heizung
2021-09-27 17:59:30.312 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2021-09-27 17:59:30.313 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
