Hello all,
I have a strange issue lately. When I connect to OH directly I can see the Things as normal, but when I connect via the cloud I can only see the status and cannot edit (both via computer and mobile phone).
I have already tried a restart, re-install of the binding but no change. Anybody knows what could be wrong or how I can diagnose?
Thanks,
Uitgeslapen
dirkdirk
(Dirk)
December 20, 2024, 10:57am
2
Same for me. Must be related to 4.3 update I guess.
Yes also running on 4.3.0
rlkoshak
(Rich Koshak)
December 20, 2024, 4:35pm
4
I’m seeing the same.
Please file an issue with the openhab-webui repo.
opened 06:15PM - 20 Dec 24 UTC
bug
main ui
Please DO NOT ERASE this template, but fill in the details as requested. T… his will ensure your issue is properly filed and will be considered. Otherwise, we may reserve the right to close it without further action.
## The problem
Describe the issue you're having. In most cases it is appreciated to share screenshots or
even animated GIFs of your issue.
To make screenshots:
* On Windows: use Win+Shift+S
* On macOS: use Cmd+Shift+4
To make animated GIFs we recommend:
* On Windows: ShareX - https://getsharex.com/
* On macOS: Giphy Capture - https://giphy.com/apps/giphycapture
* On GNU/Linux: Peek - https://github.com/phw/peek
## Expected behavior
Things to shows the same between direct LAN connection and cloud connection.
Describe what you expected to happen or how it should look/behave.
## Steps to reproduce
Reproduces constantly, no action needed. Just open any Thing.
Provide accurate steps to reproduce the issue, including pastes of widget/page code if necessary.
## Your environment
4.3.0
As an admin, in the main UI, choose *Help & About* on the left sidebar, expand *Technical information* and click on *View details*, then click *Copy* and paste the results here. You may omit information that is not pertinent to this issue if you feel it's divulging information you'd like not to share.
## Browser console
Open the developer tools in your browser, go to the Console tab and paste errors and other messages that might be relevant to this issue.
You may also paste a screenshot if you prefer.
Doesn't mather, both phone and computer.
## Browser network traffic
NA
Open the developer tools in your browser, go to the Network tab and paste
screenshots of the network traffic and the details of individual requests that failed.
## Additional information
NA
Provide any information not pertinent to the above sections that you'd still like to share.
Done.
Best regards,
uitgeslapen
Are you guys running on a vpn?? I have a corporate vpn running and with it on I see the same.
rlkoshak
(Rich Koshak)
December 20, 2024, 7:04pm
7
I have tailscale up and running on the machine I tested on.
But when connected via the cell network with tailscale turned off I get the same result. The Thing’s page is as shown above.
I was indeed running via VPN in the screenshot, but also without get the same result.
I closed the issue, couldn’t answer the questions asked. If somebody is more knowledgeable feel free to open a new one.
HenMus
(Hen Mus)
February 13, 2025, 10:22am
10
Because I have the same problem I was reading all the links and found it is fixed in
jlaur added this to the 5.0 milestone on Dec 28, 2024
Is there a fix for 4.3.0?
It is part of 4.3.1 and newer.
