This rule doesn't work
Hi all,
This rule
rule "Temperatuurcontrole en Verwarming"
    Item GameRoom_temp changed
    // Lees de huidige temperatuurwaarde uit
    val Number currentTemperature = GameRoom_temp.state as Number
    // Toegevoegde logboekverklaring
    logInfo("HeatingRule", "Check temp gameroom.")
    logInfo("HeatingRule", "Huidige temperatuurwaarde: {}", currentTemperature)
    // Controleer of de temperatuur lager is dan 14 graden en zet de verwarming aan
    if (currentTemperature < 14 && Heater_Game_Room_Switch.state != ON) {
        Heater_Game_Room_Switch.sendCommand(ON)
    // Controleer of de temperatuur gelijk is aan of hoger dan 18 graden en zet de verwarming uit
    else if (currentTemperature >= 18 && Heater_Game_Room_Switch.state != OFF) {
        Heater_Game_Room_Switch.sendCommand(OFF)
Doesn’t seem to work. Must be pretty simple but I cannot figure it out.
Can anybody see what I am missing here?
The switch does not turn ON or OFF. The loginfo does indicate that the currenttemperature readout is correct.
I can also see that the switch is in the correct state. Some how there is no sendcommand action
I see two potential problems
  1. Replace ON and OFF by “ON” and “OFF”
  2. Is your item currentTemperature a number item or of unit temperature? If it is unit based please search in the docs for „Unit of Measurement“ how to deal with them.
That’s not necessary in Rules DSL. That part of the code will work as written.
It helps us a lot to see these logs. I suspect @Oliver2’s 2 is on the right track but the logs will confirm it. In particular if the log says “Huidige temperatuurwaarde: 22 °C” (for example) as opposed to “Huidige temperatuurwaarde: 22” that would indicate that the. problem is related to units.
I think that could be the issue. As this is the output of the log:
2023-12-18 19:12:42.508 [INFO ] [penhab.core.model.script.HeatingRule] - Check temp gameroom.
2023-12-18 19:12:42.510 [INFO ] [penhab.core.model.script.HeatingRule] - Huidige temperatuurwaarde: 10.75 °C
I removed the as Number and put | ℃ behind the 14 and 18
Now the rule works.
Thanks for pointing me in the right direction
