I am using an EnOcean rocker with 4 taps to control a set of 3 Hues (all 3 in parallel, i. e. same brightness and color temperature). A short click sets brightness and color temperature to 100 or 0 percent, a longer (holding) click dims up or down. The functionality is inspired from Kai’s Enocean video.
Variables brightIter1, warmIter1 are used to keep track of how many iterations have been counted. If the value of such an iteration variable is still low (i. e. not much time has passed when depressing), then an instant 100 or 0 percent are set. That does work.
Not working however is the longer click: I understand that createTimer() creates a new thread, however besides receiving a timely “OFF”, the dimming threads are never stopped. They run all the way through to 100 or to 0.
The code is quite lengthy. - Any suggestions on improving this - please comment.
var Timer brightTimer1 = null // may not contain underscores?!
var Timer warmTimer1 = null
var PercentType brightPercent1 = new PercentType(0)
var PercentType warmPercent1 = new PercentType(0)
var Integer brightIter1 = new Integer(0)
var Integer warmIter1 = new Integer(0)
var Timer brightTimer2 = null
var Timer warmTimer2 = null
var PercentType brightPercent2 = new PercentType(0)
var PercentType warmPercent2 = new PercentType(0)
var Integer brightIer2 = new Integer(0)
var Integer warmIter2 = new Integer(0)
rule "FT4_1 for Licht @EG brighter"
Item FT4_1_A_Up received update
if(FT4_1_A_Up.toString().contains("ON")) {
brightTimer1 = createTimer(now.plusSeconds(1)) [|
for(i: 1..10) {
brightIter1 = new Integer(brightIter1.intValue + 1)
brightPercent1 = new PercentType(brightPercent1.intValue + 10)
sendCommand(Hue_Dimm_1, brightPercent1)
sendCommand(Hue_Dimm_3, brightPercent1)
sendCommand(Hue_Dimm_5, brightPercent1)
if(brightPercent1.intValue > 100) brightPercent1 = new PercentType(100)
Thread::sleep(1000)
} else if(FT4_1_A_Up.toString().contains("OFF")) {
brightTimer1.cancel
brightTimer1 = null
if(brightIter1.intValue < 2) {
rule "FT4_1 for Licht @EG darker"
Item FT4_1_A_Dn received update
if(FT4_1_A_Dn.toString().contains("ON")) {
for(i: 1..10) {
brightPercent1 = new PercentType(brightPercent1.intValue - 10)
if(brightPercent1.intValue < 0) brightPercent1 = new PercentType(0)
Thread::sleep(1000)
} else if(FT4_1_A_Dn.toString().contains("OFF")) {
brightTimer1.cancel
brightTimer1 = null
rule "FT4_1 for Licht @EG warmer"
Item FT4_1_B_Up received update
if(FT4_1_B_Up.toString().contains("ON")) {
warmTimer1 = createTimer(now.plusSeconds(1)) [|
for(i: 1..10) {
warmPercent1 = new PercentType(warmPercent1.intValue + 10)
if(warmPercent1.intValue > 100) warmPercent1 = new PercentType(100)
sendCommand(Hue_CT_Dimm_1, warmPercent1)
sendCommand(Hue_CT_Dimm_3, warmPercent1)
sendCommand(Hue_CT_Dimm_5, warmPercent1)
warmIter1 = new Integer(warmIter1.intValue + 1)
Thread::sleep(1000)
} else if(FT4_1_B_Up.toString().contains("OFF")) {
warmTimer1.cancel
warmTimer1 = null
if(warmIter1.intValue < 2) {
rule "FT4_1 for Licht @EG colder"
Item FT4_1_B_Dn received update
if(FT4_1_B_Dn.toString().contains("ON")) {
for(i: 1..10) {
warmPercent1 = new PercentType(warmPercent1.intValue - 10)
if(warmPercent1.intValue < 0) warmPercent1 = new PercentType(0)
Thread::sleep(1000)
} else if(FT4_1_B_Dn.toString().contains("OFF")) {
warmTimer1.cancel
warmTimer1 = null
Keeps dimming down besides releasing the button:
2017-06-16 06:02:47 - FT4_1_A_Dn state updated to ON
2017-06-16 06:02:48 - Hue_Dimm_1 received command 100
2017-06-16 06:02:48 - Hue_Dimm_3 received command 100
2017-06-16 06:02:48 - Hue_Dimm_5 received command 100
2017-06-16 06:02:50 - Hue_Dimm_1 received command 90
2017-06-16 06:02:50 - Hue_Dimm_3 received command 90
2017-06-16 06:02:50 - Hue_Dimm_5 received command 90
2017-06-16 06:02:50 - FT4_1_A_Dn state updated to OFF
2017-06-16 06:02:51 - Hue_Dimm_1 received command 80
2017-06-16 06:02:51 - Hue_Dimm_3 received command 80
2017-06-16 06:02:51 - Hue_Dimm_5 received command 80
2017-06-16 06:02:51 - Hue_Toggle_5 state updated to ON
2017-06-16 06:02:51 - Hue_CT_Dimm_5 state updated to ON
2017-06-16 06:02:51 - Hue_Dimm_1 state updated to 80
2017-06-16 06:02:51 - Hue_Color_1 state updated to 189.642857142857138796898652799427509307861328125,93,80
2017-06-16 06:02:51 - Hue_Color_5 state updated to ON
2017-06-16 06:02:51 - Hue_Color_5 state updated to 189.642857142857138796898652799427509307861328125,93,80
2017-06-16 06:02:51 - Hue_Color_3 state updated to 189.642857142857138796898652799427509307861328125,93,80
2017-06-16 06:02:51 - Hue_Dimm_3 state updated to 80
2017-06-16 06:02:51 - Hue_Dimm_5 state updated to ON
2017-06-16 06:02:51 - Hue_Dimm_5 state updated to 80
2017-06-16 06:02:52 - Hue_Dimm_1 received command 70
2017-06-16 06:02:52 - Hue_Dimm_3 received command 70
2017-06-16 06:02:52 - Hue_Dimm_5 received command 70
