So I have the following rule
rule "Forgot door Open"
Item HallwayDoorSensor_DoorSensor changed from CLOSED to OPEN
Thread::sleep(30000)
logInfo("SurveillanceCheck", "Usa de la intrare s-a deschis")
if (HallwayDoorSensor_DoorSensor.state == OPEN)
sendNotification (“email@gmail.com","Usa de la intrare a ramas deschisa")
logInfo("SurveillanceCheck", "Usa de la intrare a ramas " + HallwayDoorSensor_DoorSensor.state)
As you can see, if the door opens, it should wait 30 seconds and if the door is still opened should send a notification.
The issue is that since OH2 the notification is sent instantly, without actually waiting the 30 seconds to check if the door is still opened.
This is running on a RPi 3 with OSMC, so basically fancy raspbian.
