My Tibber binding stop getting values after midnight between sunday and monday. After disabling the Tibber thing and then enable it again it start working.
Here is my log:
2022-09-26 00:02:38.059 [DEBUG] [ibber.internal.handler.TibberHandler] - API response: {"data":{"viewer":{"home":{"currentSubscription":{"priceInfo":{"current":{"total":1.7853,"startsAt":"2022-09-26T00:00:00.000+02:00","level":"VERY_CHEAP"}}},"daily":{"nodes":[{"from":"2022-09-25T00:00:00.000+02:00","to":"2022-09-26T00:00:00.000+02:00","cost":51.6696666,"unitPrice":2.230217,"consumption":23.168,"consumptionUnit":"kWh"}]},"hourly":{"nodes":[{"from":"2022-09-25T23:00:00.000+02:00","to":"2022-09-26T00:00:00.000+02:00","cost":null,"unitPrice":0.661675,"consumption":null,"consumptionUnit":"kWh"}]}}}}}
2022-09-26 00:03:37.975 [DEBUG] [ibber.internal.handler.TibberHandler] - Error during websocket communication: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
2022-09-26 00:03:37.977 [DEBUG] [ibber.internal.handler.TibberHandler] - Sending websocket disconnect message
2022-09-26 00:03:37.977 [DEBUG] [ibber.internal.handler.TibberHandler] - Send message: {"type":"connection_terminate","payload":null}
2022-09-26 00:03:38.084 [DEBUG] [ibber.internal.handler.TibberHandler] - Closing a WebSocket due to Disconnected
2022-09-26 00:03:38.139 [DEBUG] [ibber.internal.handler.TibberHandler] - API response: {"data":{"viewer":{"home":{"currentSubscription":{"priceInfo":{"current":{"total":1.7853,"startsAt":"2022-09-26T00:00:00.000+02:00","level":"VERY_CHEAP"}}},"daily":{"nodes":[{"from":"2022-09-25T00:00:00.000+02:00","to":"2022-09-26T00:00:00.000+02:00","cost":51.6696666,"unitPrice":2.230217,"consumption":23.168,"consumptionUnit":"kWh"}]},"hourly":{"nodes":[{"from":"2022-09-25T23:00:00.000+02:00","to":"2022-09-26T00:00:00.000+02:00","cost":null,"unitPrice":0.661675,"consumption":null,"consumptionUnit":"kWh"}]}}}}}
2022-09-26 00:03:38.142 [DEBUG] [ibber.internal.handler.TibberHandler] - Attempting to reopen Websocket connection
2022-09-26 00:03:53.090 [WARN ] [org.eclipse.jetty.io.ManagedSelector] - java.nio.channels.ClosedSelectorException
2022-09-26 00:03:53.090 [WARN ] [ibber.internal.handler.TibberHandler] - CLOSE FRAME - Failed to stop websocket client: null
2022-09-26 00:03:53.201 [DEBUG] [ibber.internal.handler.TibberHandler] - New socket being created
2022-09-26 00:03:53.203 [DEBUG] [ibber.internal.handler.TibberHandler] - Starting Websocket connection
2022-09-26 00:03:53.208 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@732d2941[provider=null,keyStore=null,trustStore=null]
2022-09-26 00:03:53.208 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@732d2941[provider=null,keyStore=null,trustStore=null]
2022-09-26 00:03:53.209 [DEBUG] [ibber.internal.handler.TibberHandler] - Connecting Websocket connection
2022-09-26 00:03:53.390 [DEBUG] [ibber.internal.handler.TibberHandler] - Sending websocket connect message
2022-09-26 00:03:53.390 [DEBUG] [ibber.internal.handler.TibberHandler] - Send message: {"type":"connection_init", "payload":"token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"}
2022-09-26 00:03:53.439 [DEBUG] [ibber.internal.handler.TibberHandler] - Connected to Server
2022-09-26 00:03:53.439 [DEBUG] [ibber.internal.handler.TibberHandler] - Send message: {"id":"1","type":"start","payload":{"variables":null,"extensions":null,"operationName":null,"query":"subscription {\n liveMeasurement(homeId:\"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX\") {\n timestamp\n power\n lastMeterConsumption\n accumulatedConsumption\n accumulatedCost\n currency\n minPower\n averagePower\n maxPower\nvoltagePhase1\n voltagePhase2\n voltagePhase3\n currentL1\n currentL2\n currentL3\n powerProduction\n accumulatedProduction\n minPowerProduction\n maxPowerProduction\n }\n }\n"}}
2022-09-26 00:03:53.553 [DEBUG] [ibber.internal.handler.TibberHandler] - Error/terminate received from server: {"type":"data","id":"1","payload":{"errors":[{"message":"unable to start stream api:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX for device XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","locations":[{"line":2,"column":2}],"path":["liveMeasurement"]}]}}
2022-09-26 00:03:53.553 [DEBUG] [ibber.internal.handler.TibberHandler] - Sending websocket disconnect message
2022-09-26 00:03:53.553 [DEBUG] [ibber.internal.handler.TibberHandler] - Send message: {"type":"connection_terminate","payload":null}
2022-09-26 00:03:53.555 [DEBUG] [ibber.internal.handler.TibberHandler] - Closing a WebSocket due to Disconnected
2022-09-26 00:04:03.211 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.tibber.internal.handler.TibberHandler.open(TibberHandler.java:345) ~[?:?]
at org.openhab.binding.tibber.internal.handler.TibberHandler.updateRequest(TibberHandler.java:248) ~[?:?]
at org.openhab.binding.tibber.internal.handler.TibberHandler.lambda$0(TibberHandler.java:236) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
2022-09-26 00:04:23.556 [WARN ] [ibber.internal.handler.TibberHandler] - CLOSE FRAME - Failed to stop websocket client: java.lang.InterruptedException
I have a script rule that runs every time current price is changed. I don’t know if that can cause the problem as it also connects to Tibber API. But the think is that this problem only happens at midnight between sundays and mondays.
However, here is my rule script:
* SET PRICE LEVEL AS NUMBER FROM TIBBER
* Gets todays electrical prices and sort them by price level and then set current price level to an item.
// Load librarys from Openhab
var logger = Java.type('org.slf4j.LoggerFactory').getLogger('org.openhab.rule.rUpdatePriceLevel2');
var newHashMap = Java.type("java.util.HashMap");
// Declare Tibber constants
var TIBBER_API_URL = "https://api.tibber.com/v1-beta/gql";
var TIBBER_TOKEN = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
var TIBBER_HOMEID = 0;
// Various declarations
var HEADERS_TIBBER = new newHashMap();
var TIMEOUT = 5000; //ms
var HTTP = Java.type("org.openhab.core.model.script.actions.HTTP");
// Tibber API query. Tibber uses GraphQL. Wrap as a JSON string for Req.body
var query = '{ "query": "{viewer {homes {currentSubscription {priceInfo {today {total}current {total}}}}}}" }';
var totalPriceArray = [];
var currentPrice;
var priceLevel;
var priceAverage = 0.0;
var priceMedian = 0.0
// Define Tibber Headers
HEADERS_TIBBER.put("Authorization", "Bearer " + TIBBER_TOKEN);
var success = false;
var res;
// Send request to Tibber. Expect JSON response.
try {
res = HTTP.sendHttpPostRequest(TIBBER_API_URL, "application/json", query, HEADERS_TIBBER, TIMEOUT);
success = true; //Quick and dirty way to stop injecting data to influx on data retrievel error.
} catch (error) {
logger.info("An error occured: " + error.message);
success = false;
if (success) {
res = JSON.parse(res);
currentPrice = JSON.stringify(res.data.viewer.homes[TIBBER_HOMEID].currentSubscription.priceInfo.current["total"]);
res = res.data.viewer.homes[TIBBER_HOMEID].currentSubscription.priceInfo.today;
for(var i in res) {
totalPriceArray.push(JSON.stringify(res[i]["total"]));
priceAverage = priceAverage + parseFloat(JSON.stringify(res[i]["total"]));
totalPriceArray.sort(function(a, b){return a-b});
priceAverage = priceAverage / 24.0;
priceMedian = (parseFloat(totalPriceArray[11]) + parseFloat(totalPriceArray[12])) / 2.0;
priceLevel = totalPriceArray.indexOf(currentPrice) + 1;
items.getItem("TibberAPI_PriceLevel2").postUpdate(priceLevel);
items.getItem("TibberAPI_PriceAverage").postUpdate(priceAverage.toFixed(4));
items.getItem("TibberAPI_PriceMedian").postUpdate(priceMedian.toFixed(4));
// logger.info("Current price: " + currentPrice);
// logger.info("Todays prices: " + totalPriceArray.toString());
