You might consider building your own Garadget device, or pre-ordering one. It uses the strength of reflected laser light to determine if the garage door is open.
Thanks. I had a look at garadget and i don’t really need the actuators at the moment, just need a door status… So for the sakes of cash in my pocket, I’ll give an 8266+reed switch a go. Should set me back about 30 dollars, maybe less if I can hook up two reed switches onto one set of 8266 gpios
anyone know if it’s possible to hook up 2 reed sensors onto separate IO pins? Given that it relies on pulldown to GND on a certain switchpin (the guy connected it to D3 in the tutorial), could I connect 2 separate reeds to D2/GND and D3/GND then modify the code section to send a slightly different MQTT message to my OH?
Monoprice has a zwave garage sensor for about $20 (they also sell it on Amazon). It’s just a tilt sensor with an extra input terminal for an additional contact (like a reed switch). Comes with the required lithium battery. I have one in my zwave network, but haven’t integrated it into OH yet…
