I try to compare dates/times of different sources, now() and from CalDAV.
CalDAV returns a date with GJChronology[Europe/Berlin] while now returns a value with ISOChronology[Europe/Berlin].
As consequence the difference of the times has a deviation of one hour.
I think, that there are two possibilities to solve it:
- handle it accordingly in the rule
- configure the calendar-server (in my case davical) to deliver ISO.
In both cases I have no clue how to solve it.
So far my config in OH2:
items:
String sCalInfo_Name1 "Termin 1 [%s]" <none> { caldavPersonal="calendar:HA_Info type:UPCOMING eventNr:1 value:NAME" }
DateTime dtCalInfo_Time1 "Zeit Termin 1 [%1$td.%1$tm. %1$tR]" <none> { caldavPersonal="calendar:HA_Info type:UPCOMING eventNr:1 value:START" }
String sCalInfo_Name2 "Termin 2 [%s]" <none> { caldavPersonal="calendar:HA_Info type:UPCOMING eventNr:2 value:NAME" }
DateTime dtCalInfo_Time2 "Zeit Termin 2 [%1$td.%1$tm. %1$tR]" <none> { caldavPersonal="calendar:HA_Info type:UPCOMING eventNr:2 value:START" }
// Beginn des Termins in ca. 12 Stunden
// Kalender wird alle 10 Minuten abgefragt, es soll nur eine Nachricht versendet werden
val Functions$Function2 EreignisNachricht12h = [
StringItem parEreignisname, // Item für Text
DateTimeItem parZeit // Item für Zeitpunkt
if (parZeit.state != UNDEF)
logInfo("EN12h", parEreignisname.state + " " + parZeit.state.toString + " " + parZeit.name)
var DateTime NowPlus12 = new DateTime(now.toDateTime.plusHours(12))
logInfo("Kalender1", NowPlus12.toString + " " + NowPlus12.chronology)
var DateTime Ereignis = new DateTime((parZeit.state as DateTimeType).calendar)
logInfo("Kalender2", Ereignis.toString + " " + Ereignis.chronology)
var DateTime Diff = NowPlus12.minus(Ereignis.millis)
logInfo("Kalender3", Diff.toString + " " + Diff.chronology)
if ( NowPlus12.minus(Ereignis.millis).getMinuteOfDay < 10)
logInfo("EN12h", parZeit.state.toString)
sendTelegram("Haus", "Folgender Termin steht an:\r\n" + parEreignisname.state)
// 12 Stunden vor Ereignis Telegram versenden
// alle 10 Minuten prüfen
rule "Kalender Info-Email 12 Stunden vor dem Ereignis"
Time cron "0 0/5 * * * ?"
EreignisNachricht12h.apply(sCalInfo_Name1, dtCalInfo_Time1)
EreignisNachricht12h.apply(sCalInfo_Name2, dtCalInfo_Time2)
result in logfile:
2017-01-15 10:40:03.431 [INFO ] [pse.smarthome.model.script.Kalender1] - 2017-01-15T22:40:03.425+01:00 ISOChronology[Europe/Berlin]
2017-01-15 10:40:03.472 [INFO ] [pse.smarthome.model.script.Kalender2] - 2017-01-15T22:00:00.000+01:00 GJChronology[Europe/Berlin]
2017-01-15 10:40:03.516 [INFO ] [pse.smarthome.model.script.Kalender3] - 1970-01-01T01:40:03.425+01:00 ISOChronology[Europe/Berlin]
