Virtual beer for you! Cheers @Udo_Hartmann !!
Running openHAB 2.2.0 Build #1112, it appears getCalendar() is now deprecated?
The method getCalendar() from the type DateTimeType is deprecated
Any ideas how I might tweak this rule to work?
rule “Get time period for right now”
System started
logInfo(“EXTRA”, “System started, attempting to get time period for right now”)
val now = new Date()
val dawn = new Date((DawnStart_Time.state as DateTimeType).calendar.timeInMillis)
val day = new Date((DayStart_Time.state as DateTimeType).calendar.timeInMillis)
val dusk = new Date((DuskStart_Time.state as DateTimeType).calendar.timeInMillis)
val night = new Date((NightStart_Time.state as DateTimeType).calendar.timeInMillis)val String initStr = "Initializing time period. The time of day is "
http://docs.openhab.org/configuration/rules-dsl.html#datetime-item
This should be useful.
The Design Pattern: Time Of Day has been updated since this posting (maybe was written after it actually) which has a little bit more concise implementation.
Hi All. i have tried this and ended up with some errors .
Part 1
2020-05-13 17:28:44.114 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:29:43.768 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:30:44.049 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:31:44.078 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:32:44.340 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:33:44.162 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:34:43.650 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:35:44.118 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:36:44.106 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:37:44.539 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:38:43.816 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:39:45.071 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:40:27.095 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
java.lang.RuntimeException: {"error":"timeout"}
at org.influxdb.impl.InfluxDBErrorHandler.handleError(InfluxDBErrorHandler.java:19) ~[influxdb-java-2.2.jar:?]
2020-05-13 17:40:43.957 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:41:12.371 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
2020-05-13 17:41:46.163 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:42:10.653 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Get time period for right now': Could not cast NULL to org.eclipse.smarthome.core.library.types.DateTimeType; line 13, column 26, length 36
2020-05-13 17:42:22.685 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Get time period for right now': Could not cast NULL to org.eclipse.smarthome.core.library.types.DateTimeType; line 13, column 26, length 36
2020-05-13 17:42:30.873 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:30.874 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:30.875 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:30.876 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:30.877 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:30.877 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:33.040 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:33.042 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:33.043 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:33.044 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:33.045 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:33.045 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:42:44.260 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:43:02.953 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:02.954 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:02.956 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:02.957 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:02.958 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:02.960 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:32.817 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:32.820 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:32.822 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:32.823 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:32.824 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:32.825 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:43:44.264 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:44:02.989 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:02.991 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:02.994 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:02.997 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:02.998 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:02.999 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:33.434 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:33.435 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:33.436 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:33.437 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:33.438 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:33.439 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:44:44.262 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs'
2020-05-13 17:45:03.416 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:45:03.417 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunriseStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:45:03.418 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:45:03.419 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SunsetStart_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-05-13 17:45:03.420 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
Items
// Times of Day
String TimePeriodOfDay "Time of Day [%s]"
DateTime DawnStart_Time "Dawn Start [%1$tH:%1$tM]" { channel="astro:sun:local:civilDawn#start" }
DateTime DawnStop_Time "Dawn Stop [%1$tH:%1$tM]" { channel="astro:sun:local:civilDawn#end" }
DateTime DayStart_Time "Day Start [%1$tH:%1$tM]" { channel="astro:sun:local:daylight#start" }
DateTime DayStop_Time "Day Stop [%1$tH:%1$tM]" { channel="astro:sun:local:daylight#end" }
DateTime DuskStart_Time "Dusk Start [%1$tH:%1$tM]" { channel="astro:sun:local:civilDusk#start" }
DateTime DuskStop_Time "Dusk Stop [%1$tH:%1$tM]" { channel="astro:sun:local:civilDusk#end" }
DateTime NightStart_Time "Night Start [%1$tH:%1$tM]" { channel="astro:sun:local:night#start" }
DateTime NightStop_Time "Night Stop[%1$tH:%1$tM]" { channel="astro:sun:local:night#end" }
DateTime MorningNightStart_Time "MorningNightStart [%1$tH:%1$tM]" { channel="astro:sun:local:morningNight#start" }
DateTime MorningNightStop_Time "MorningNightStop [%1$tH:%1$tM]" { channel="astro:sun:local:morningNight#end" }
DateTime EveningNightStart_Time "EveningNightStart [%1$tH:%1$tM]" { channel="astro:sun:local:eveningNight#start" }
DateTime EveningNightStop_Time "EveningNightStop [%1$tH:%1$tM]" { channel="astro:sun:local:eveningNight#end" }
// Events
Switch DawnStart_Event "Start of Dawn Event"
Switch DayStart_Event "Start of Day Event"
Switch DuskStart_Event "Start of Dusk Event"
Switch NightStart_Event "Start of Night Event"
// Items
Switch Dawn "Dawn [%s]" // After Dawn and before Day
Switch Day "Day [%s]" // After Day and before Dusk
Switch Dusk "Dusk [%s]" // After Dusk and before Night
Switch Night "Night [%s]" // After Night and before Dawn
Number SunAzimuth "Azimuth [%.0f °]" { channel="astro:sun:local:position#azimuth" }
Number SunElevation "Elevation [%.0f °]" { channel="astro:sun:local:position#elevation" }
String MoonPhase "MoonPhase [%s]" { channel="astro:moon:local:phase#name" }
Rule :
import java.util.Date
// Time of Day Rules
// Requires time update every 60 seconds
val String RFN = "time-of-day.rules"
rule "Get time period for right now"
System started
if(now.after(dawn) && now.before(day)) {
logInfo(RFN, initStr + "Dawn: " + now)
Dawn.sendCommand(ON)
Day.sendCommand(OFF)
Dusk.sendCommand(OFF)
Night.sendCommand(OFF)
TimePeriodOfDay.postUpdate("Dawn")
else if(now.after(day) && now.before(dusk)) {
logInfo(RFN, initStr + "Day: " + now)
Dawn.sendCommand(OFF)
Day.sendCommand(ON)
TimePeriodOfDay.postUpdate("Day")
else if(now.after(dusk) && now.before(night)) {
logInfo(RFN, initStr + "Dusk: " + now)
Dusk.sendCommand(ON)
TimePeriodOfDay.postUpdate("Dusk")
else {
logInfo(RFN, initStr + "Night: " + now)
Night.sendCommand(ON)
TimePeriodOfDay.postUpdate("Night")
rule "Generate Time of Day Events"
Item CurrentTime received update
val sunset = new Date((SunsetStart_Time.state as DateTimeType).calendar.timeInMillis)
val sunrise = new Date((SunriseStart_Time.state as DateTimeType).calendar.timeInMillis)
if((now.getTime-(now.getTime%60000)) == (dawn.getTime-(dawn.getTime%60000))) {
logInfo(RFN, "Transitioning to Dawn!!!")
DawnStart_Event.postUpdate(ON)
else if((now.getTime-(now.getTime%60000)) == (day.getTime-(day.getTime%60000))) {
logInfo(RFN, "Transitioning to Day!!!")
DayStart_Event.postUpdate(ON)
else if((now.getTime-(now.getTime%60000)) == (dusk.getTime-(dusk.getTime%60000))) {
logInfo(RFN, "Transitioning to Dusk!!!")
DuskStart_Event.postUpdate(ON)
else if((now.getTime-(now.getTime%60000)) == (night.getTime-(night.getTime%60000))) {
logInfo(RFN, "Transitioning to Night!!!")
NightStart_Event.postUpdate(ON)
if((now.getTime-(now.getTime%60000)) == (sunrise.getTime-(sunrise.getTime%60000))) {
logInfo(RFN, "Start of Sunrise!")
SunriseStart_Event.postUpdate(ON)
else if((now.getTime-(now.getTime%60000)) == (sunset.getTime-(sunset.getTime%60000))) {
logInfo(RFN, "Start of Sunset!")
SunsetStart_Event.postUpdate(ON)
rule "Dawn Started"
Item DawnStart_Event received update ON
logInfo(RFN, "Its Dawn: " + now)
rule "Day Started"
Item DayStart_Event received update ON
logInfo(RFN, "Its Day: " + now)
Day.sendCommand(ON)
rule "Dusk started"
Item DuskStart_Event received update ON
logInfo(RFN, "Its Dusk: " + now)
rule "Night started"
Item NightStart_Event received update ON
val morningNightStart = new Date((MorningNightStart_Time.state as DateTimeType).calendar.timeInMillis)
val morningNightStop = new Date((MorningNightStop_Time.state as DateTimeType).calendar.timeInMillis)
val eveningNightStart = new Date((EveningNightStart_Time.state as DateTimeType).calendar.timeInMillis)
val eveningNightStop = new Date((EveningNightStop_Time.state as DateTimeType).calendar.timeInMillis)
if((now.after(morningNightStart) && now.before(morningNightStop)) ||
(now.after(eveningNightStart) && now.before(eveningNightStop))) {
logInfo(RFN, "Its Night: " + now)
rule "Sunrise started"
Item SunriseStart_Event received update ON
logInfo(RFN, "Its Sunrise : " + now)
rule "Sunset started"
Item SunsetStart_Event received update ON
logInfo(RFN, "Its Sunset : " + now)
RestDocs moved from the misc category to the UIs category in OH 2.4 I think, maybe early on in OH 2.5. There are lots of threads discussing it with solutions.
And since the Astro binding supports events now (and has for some years) this particular approach is somewhat archaic.
Thank you. Will look in to it.
