I have put a door/window sensor from xiaomi in my mailbox so I can see when it was opened/closed.
What I now want to do is to light up my hue bulb whenever the mailbox was opened/closed but the rule should only trigger between 7:00 and 23:59
This is my current approach. The problem is that the light does not get turned on:
var Number currenthour = now.getHourOfDay
var String briefkastenvoll = "252,100,50"
rule "Briefkasten Status"
Item XiaomiDoorWindowSensorBriefkasten_OpenStatus changed to CLOSED
if(currenthour >= 7)
Lampe_Color.sendCommand(briefkastenvoll)
sendBroadcastNotification("Briefkasten: Sie haben Post!")
Briefkastengeleert.sendCommand(ON)
As you can see in the logs the rule should have triggered, what did I do wrong ?
2018-03-15 11:39:08.769 [vent.ItemStateChangedEvent] - XiaomiDoorWindowSensorBriefkasten_OpenStatus changed from CLOSED to OPEN
2018-03-15 11:39:09.500 [vent.ItemStateChangedEvent] - XiaomiDoorWindowSensorBriefkasten_OpenStatus changed from OPEN to CLOSED
Your variable is not in the scope of the rule and will only be evaluated once at startup
I just made the change as you suggested but and tried if the lights get turned on once I open the mailbox. Still nothing happend. What could be the reason?
2018-03-15 13:13:46.054 [vent.ItemStateChangedEvent] - XiaomiDoorWindowSensorBriefkasten_OpenStatus changed from OPEN to CLOSED
var Number currenthour = now.getHourOfDay()
logInfo("Rule Testing", currenthour.toString)
Yes I understood. But before your comment I thought it would always get refreshed even as global variable. Because I thought it would be refreshed with everytime the .rules file is used.
Thanks for pointing this out! This helps me a lot.
