There is no openHAB 4 release and please don‘t expect everything working on early SNAPSHOTS.
We have not looked into oh4 for the main widget and this will take more time.
Yes i meant oh4 snapshot release,and yes i know that could be “risky”…
As you are brave enough to install 4.0 snapshot, you might want to try to install the NASHORN addon:
see /settings/addons/marketplace:134770
It may give you some compatibility…
at your own risk
I had already installed but the time picker seems to ignore it…
Any idea of a widget that can do the something like time picker?
Edit: mmm not sure i have that version…but i can’t find the one of your screen…
MainUI is running separately from the OH core. The OH core java version with its embedded JavaScript should have no impact on the MainUI which is a web app that is running in the JavaScript engine of your browser…
I haven’t moved to the 4.0 snapshot yet, but if MainUI is running at all then it has compiled properly and that means that the dayjs library has been successfully included with all its prerequisites. So, most likely something else is going on here to cause the issue you are seeing.
You’ll have to give us more info about the problem: how do you know it’s not working? Are there any errors in the logs? Are there any errors in the browser console? What config parameters are you using for the widget? Etc.
yes you’re right, sorry.
ok, following there is the complete widget. it’s a rollershutter widget that has the option to manage the automatic open/close time, based on the time picker of this topic.
it was working perfectly, then i had an issue (maybe related to a binding) that “forced” me to do an upgrade. i completely forgot that pending there was the OH4, so it has been installed automatically.
on next boot, i’ve seen that the widget, the time picker part, was not working, or better, numbers when clicking “up arrow” or “down arrow” were not changing.
hours and minutes are based on 2 DateTime items. if i update the status of those items by api explorer, automatic open/close works, but i’m not able to manage hours/minutes from the widget.
i’ve checked in log, but nothing happens.
i deduce tha issue come from JS because i’ve seen another error in logs related to a script that determine the OH running time.
looking into the widget code, i’ve seen that points to JS, so i think that everything it’s related to Java version 17.
hope i’ve fully explained the issue, but if i can help in a better way, i will do.
thanks a lot to all guys|
uid: Universal_Rollershutter_Card
tags: []
props:
parameters:
- context: Text
description: Title of the card
label: Title
required: false
type: TEXT
- context: item
description: Rollershutter Item
label: Rollershutter Item
required: true
type: TEXT
- context: item
description: Enable Opening Schedule
label: Enable Schedule Opening Item
required: false
type: TEXT
- context: item
description: Enable Closure Schedule
label: Enable Schedule Closure Item
required: false
type: TEXT
- context: item
description: Opening Time
label: Opening Time Item
required: false
type: TEXT
- context: item
description: Closure Time
label: Closure Time Item
required: false
type: TEXT
timestamp: Dec 20, 2022, 7:16:22 PM
component: f7-card
style:
background: '=themeOptions.dark === "dark" ? "rgb(40, 40, 40)" : "rgb(240, 240, 240)"'
box-shadow: 5px 5px 15px 1px rgba(0,0,0,0.3)
margin-left: 5px
margin-right: 5px
slots:
default:
- component: f7-card-content
style:
position: relative
z-index: 3
slots:
default:
- component: f7-row
style:
margin-bottom: -10px
margin-left: 0px
margin-right: 0px
slots:
default:
- component: f7-col
style:
margin-left: 0px
margin-right: 0px
width: 60px
slots:
default:
- component: oh-icon
height: 50px
icon: iconify:ic:twotone-roller-shades
style:
color: orange
- component: f7-col
style:
margin-left: 60px
margin-right: 0px
position: absolute
width: 80%
slots:
default:
- component: f7-row
slots:
default:
- component: Label
style:
color: '=themeOptions.dark === "dark" ? "white" : "black"'
font-size: 15px
font-weight: 500
text: =props.rollerTitle
- component: f7-row
style:
align-items: right
display: flex
flex-direction: row
slots:
default:
- component: f7-chip
style:
background: orange
color: black
font-weight: 500
text: '=items[props.groupItem].state == "100" || items[props.groupItem].displayState == "100" ? "Closed" : items[props.groupItem].state == "0" || items[props.groupItem].displayState == "0" ? "Open" : items[props.groupItem].state + "% closed" || items[props.groupItem].displayState + "% closed"'
- component: f7-col
style:
margin-left: 0px
margin-right: 0px
width: 26px
slots:
default:
- component: oh-link
action: command
actionCommand: UP
actionItem: =props.groupItem
iconColor: orange
iconF7: arrow_up_circle
iconSize: 28
style:
z-index: 98
action: command
actionCommand: STOP
iconF7: stop_circle
iconSize: 28
style:
z-index: 98
action: command
actionCommand: DOWN
iconColor: orange
iconF7: arrow_down_circle
iconSize: 28
style:
z-index: 98
class: align-items-center alignt-text-center justify-content-center
style:
margin-left: 15px
margin-right: 15px
position: relative
z-index: 2
visible: =(vars.PresetVisible) == true
slots:
default:
- component: f7-row
slots:
default:
- component: oh-slider
color: orange
item: =props.groupItem
max: 100
min: 0
step: "1"
style:
background: trasparent
color: black
font-size: 13px
- component: f7-row
style:
margin-top: 15px
slots:
default:
- component: oh-button
action: command
actionCommand: 25
round: true
style:
background: '=items[props.groupItem].state >= "20" && items[props.groupItem].state <= "30" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 25
action: command
actionCommand: 40
round: true
style:
background: '=items[props.groupItem].state >= "35" && items[props.groupItem].state <= "45" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 40
action: command
actionCommand: 50
round: true
style:
background: '=items[props.groupItem].state >= "45" && items[props.groupItem].state <= "55" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 50
action: command
actionCommand: 75
round: true
style:
background: '=items[props.groupItem].state >= "70" && items[props.groupItem].state <= "80" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 75
action: command
actionCommand: 90
round: true
style:
background: '=items[props.groupItem].state >= "85" && items[props.groupItem].state <= "95" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 90
class: display-flex align-items-center alignt-text-center justify-content-center
style:
margin-left: 0px
margin-right: 0px
margin-top: -10px
position: relative
z-index: 1
visible: =(vars.ScheduleVisible) == true
slots:
default:
- component: f7-row
style:
width: 300px
slots:
default:
- component: f7-col
style:
width: 100px
slots:
default:
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 100px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
text-decoration: underline
text-underline-offset: 4px
text: Opening Time
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
actionItem: =(props.OpeningTimeItem)
style:
--f7-button-text-color: orange
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.OpeningTimeItem].state === 'NULL') || !props.OpeningTimeItem) ? '?': props.timeFormat == '12h' ? dayjs(items[props.OpeningTimeItem].state).format('hh'): dayjs(items[props.OpeningTimeItem].state).format('HH'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(-1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
- component: f7-col
style:
width: 20px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ":"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.OpeningTimeItem].state === 'NULL') || !props.OpeningTimeItem) ? '?': dayjs(items[props.OpeningTimeItem].state).format('mm'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(-1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
- component: f7-col
style:
width: 100px
slots:
default:
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 100px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
text: Closure Time
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
actionItem: =(props.ClosureTimeItem)
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.ClosureTimeItem].state === 'NULL') || !props.ClosureTimeItem) ? '?': props.timeFormat == '12h' ? dayjs(items[props.ClosureTimeItem].state).format('hh'): dayjs(items[props.ClosureTimeItem].state).format('HH'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(-1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
- component: f7-col
style:
width: 20px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ":"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.ClosureTimeItem].state === 'NULL') || !props.ClosureTimeItem) ? '?': dayjs(items[props.ClosureTimeItem].state).format('mm'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(-1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
style:
margin-bottom: -50px
margin-left: 15px
margin-right: 15px
margin-top: -50px
position: relative
z-index: 0
visible: =(vars.ChartVisible) == true
slots:
default:
- component: oh-chart
chartType: day
options:
backgroundColor: transparent
periodVisible: false
slots:
grid:
- component: oh-chart-grid
containLabel: false
series:
- component: oh-time-series
barWidth: 1
color: orange
gridIndex: 0
type: bar
xAxisIndex: 0
yAxisIndex: 0
xAxis:
- component: oh-time-axis
axisPointer:
show: false
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
min: 0
name: " % closed"
- component: f7-card-footer
style:
background: rgb(245, 218, 137)
border-radius: 0 0 10px 10px
height: auto
slots:
default:
- component: f7-block
style:
bottom: 3px
display: flex
left: 0
position: absolute
slots:
default:
action: variable
actionVariable: PresetVisible
actionVariableValue: =! (vars.PresetVisible)
slots:
default:
icon: iconify:mdi:window-shutter-auto
style:
color: "=(vars.PresetVisible ? 'rgb(255, 128, 0)' : 'rgb(106, 106, 106)')"
width: 25px
action: variable
actionVariable: ScheduleVisible
actionVariableValue: =! (vars.ScheduleVisible)
slots:
default:
icon: iconify:akar-icons:clock
style:
color: "=(vars.ScheduleVisible ? 'rgb(255, 128, 0)' : 'rgb(106, 106, 106)')"
width: 25px
icon: iconify:mdi:sort-clock-descending-outline
style:
color: green
width: 25px
- component: oh-toggle
color: green
item: =props.EnableScheduledOpening
style:
--f7-toggle-height: 20px
--f7-toggle-inactive-color: red
--f7-toggle-width: 40px
margin-left: 7px
margin-top: -2px
z-index: 98
icon: iconify:mdi:sort-clock-ascending-outline
style:
color: red
margin-left: 7px
width: 25px
color: green
item: =props.EnableScheduledClosure
style:
margin-left: 7px
margin-top: -2px
z-index: 98
action: variable
actionVariable: ChartVisible
actionVariableValue: =! (vars.ChartVisible)
slots:
default:
icon: iconify:ant-design:bar-chart-outlined
style:
color: "=(vars.ChartVisible ? 'rgb(255, 128, 0)' : 'rgb(106, 106, 106)')"
width: 25px
No, it is not, it is just one DateTime item to store the relevant information. Within the widget, this is separated into a part for the hours and one for the minutes.
yes, one for opening, and one for closing. am i wrong?
These are entirely different systems. The script JS error is simply unrelated to the widget issue.
Can you verify that after the upgrade your DateTime item is properly populated with a value? Can you verify that the widget version you are testing has the OpeningTimeItem
property correctly set? Do you see any errors in the browser console (not the openhab log, the developer view console in the browser) when you trigger the button? Is the problem fixed if you use 'YYYY-MM-DDTHH:mm:ss.SSSZZ'
as the format instead?
This is how our widget uses the timepicker, but thats not how it is working internally.
You need to be more precise on your description, otherwise it might lead into a wrong direction.
Thanks for the time you spend to try to help
I’ve tried to delte and recreate the item “AperturaTapparellaBagnoSettimanale” (openingTimeItem of the widget) set again via api explorer the date and time,the state gets the. Ew value but it’s not manageable from the widget.
The strange thing is that when i’ve deleted the item and recreated it,the value has not been resetted to NULL but it kept the same value before the deletion.
I’ve rechecked the item and eidget properties and are properly set.
Actually i’m from mobile and i cannot check if the browser shows an error when i try to change values of the item via widget…
Ok got it. the issue was on time picker widget. It’s related to time/date pattern defined in the widget.
Replacing original pattern with
It started to work again.
Thanks to all who pointed me on the right direction.
Unfortunately the time picker doesn’t work anymore on OH 4.0.1 Release. Even when I alter the DateTime parse string to
Install the JavaScript Scripting (Nashorn) AddOn
Why ??? It is running without !
u r right …
I’ve uninstalled it and it is still working
Dear all,
I migrated to OH4.1 too and had to change
Because I had a had request error from the MAIN UI.
Hello everybody,
After migration from OH 2.4 to 4.1 now, I did some adjustments on my system, and one challenge is that I would like to have a possibility of setting a time for the morning routine in the GUI. SO i try already a lot, on is this time picker - but whatever I do, i just shows just two Boxes with the arrows but questionmarls in it. I already tried to change the format like hobex46 sais in his post to YYYY-MM-DDTHH:mm:ss.0ZZ - but still it’s not doing anything.
Nay suggestion what did I miss? Is there any basic configuration i need to do earlier? Install anything? Define variables? whatsoever? Thankful for any hint!
The date time item you assign to the time picker needs to have a value before it will work. If the item is null, you will get an error. I created a temporary rule to assign it a value and then the time picker would change the value.
You don‘t need a rule. Just once give the Item a value through rest API and then persist it with MapDB persistence…
