Did I understand that right that I need to use ? for the browser
but & for the webview
webview url ="/static/Visualization/Timeline.html?Item=KG_Gaeste_Fenster&serviceId=influxdb" height = 4
In the first link, you are querying the persistence REST API directly, so, yes, you should use ?
. That wonāt be of much use in a sitemapā¦ I asked you to check if you can open the URL who was throwing the error just as a test.
On the second one, you are calling Timeline.html
and you should specify the parameters with &
I can display both Items now, open/close and 0/1.
Groups however no not work.
http://192.168.1.52:8080/static/Visualization/Timeline.html?Item=EG_Flur_Haustuer?serviceId=influxdb
works,
http://192.168.1.52:8080/static/Visualization/Timeline.html?Group=gdisplayFenster?serviceId=influxdb
does not.
items file reads:
Group gdisplayFenster
Contact EG_Flur_Haustuer āTĆ¼rā (EG_Flur, gHaustuer,gdisplayFenster) {channel=ā¦}
Using the REST API can you query persistence data for the group?
How do you persist the group?
I donāt. But gHaustuer is persisted. EG_Flur_Haustuer is a member gHaustuer. Since EG_Flur_Haustuer is the only member of gdisplayFenster I did not think that was a problem.
I was assuming that displaying the group concatenates all elements.
If i do persist the group in addition to its elements, does this result in twice the amount of data to be stored ?
If you use ServiceId=influxdb it works for Group and Item
If you use serviceId=influxdb it works for Item only
Canāt explain it. In Timeline.html it says
var serviceParameter = GetParameter(āServiceIdā);
In fact, if you use Item, you do not need any other parameter, just a ā?ā. Maybe it is then using the default persistence ?
This is the image I wanted to post further down, but the board woulnāt let meā¦
Now its up here where it doesnāt belong.
Same for longer periods, the image seems to be inverted.
Hello, I implemented this function and I just love it! only a question, when I stop on a plotted area it shows the time in 12 am/pm format even though the timeline is in the correct 24 format. And i would also like to translate in Italian the duration and hours. Can i get a clue on how to do it?Thanks in advance, GREAT JOB!!!
This is odd. If i plot 192.168.1.52:8080/static/Visualization/Timeline.html?Group=heatingTimeline&ServiceId=influxdb&Hours=28 I get:
If I plot one more hour,
192.168.1.52:8080/static/Visualization/Timeline.html?Group=heatingTimeline&ServiceId=influxdb&Hours=29
I get all values inverted. I would love to post an image of it but this software wouldnāt let me. New users are so limitedā¦
Edit: see two posts up.
Hi guys!
Sorry for my late replyā¦
Iām sorry, but I have no clue as why you are experience this. Iām no web programmer and all I did was to modify @patrik_gfellerās work with help from Google and other forums.
AFAIK, this Timeline
visualization only plots state changes, so my guess is that you donāt have enough data in your persistenceā¦ But, again, itās only a guess. Iām using this chart type in my sitemap and I didnāt have any problems with itā¦
@Melkor
Well, I also wanted to make some modifications to the tooltip display and your question was just one more push for me to try something .
So, here is what I accomplished:
For translating the labels, you can take a look in Timeline.html
and edit yourself the corresponding text (around line# 144):
entry[2] = '<div class="ggl-tooltip">' +
'<div><strong>' + label + '</strong></div>' +
'<hr>' +
'<table>' +
'<tr><td><span>Start:</span></td><td>' + formatDate(entry[4],1) + '</td></tr>' +
'<tr><td><span>End:</span></td><td>' + formatDate(entry[5],1) + '</td></tr>' +
'</table><hr><table>' +
'<tr><td><span>Duration:</span></td><td>' + duration_string + '</td></tr>' +
'</table>' +
'</div>';
For changing the datetime format, youāll have to take a look at formatDate
function (lines# 64-100). Choose another format and use it in the tooltipās definition or modify to suit your need.
It shouldnāt be complicated at all.
I updated the previous link with the new version, but, in any case here it is again.
Files modified: Visualization\Timeline.html
and css\visualizationStyle.css
All,
Thanks for this great feature. It improves my sitemap very much.
I discovered an issue with calculating the durations for the tooltip. The results always were less than 24h even if the state changes were longer than that. I have changed the calculation slightly to:
var duration = Math.trunc((entry[5] - entry[4]) / 1000);
var hours = parseInt( duration / 3600 );
var minutes = parseInt( duration / 60 ) % 60;
var seconds = duration % 60;
A second thing which seems to be nice to know for everyone is a way how to localize the timeline itself. When displaying a period longer than 24h the labels of the x-axis contain the abbreviations for the day. To streamline it with your local settings you can add the language
option while loading the visualization package.
google.charts.load("current", {
packages: ["timeline"],
language: "de"
Hi All off you
This looks absolutely awesome, but no way i can get it to work, I just get a āwhiteā space,
tried with edge an Chrome, same thing, tried the bare url in the browser : (http://192.168.0.132:8080/static/Visualization/Timeline.html?Group=gBevegelse&serviceId=rrd4j&Hours=24)
The percistance works fine as i get the Chart with the same group to work fineā¦
I downloaded Mihai_Badea html.zip, and changed the baseURL = āhttp://192.168.0.132:8080/ā still nothingā¦
Is it anything else i need to install to get this to work ?
/Ole
I had the exact same white-space-issue. What solved it for me was adding every single item I wanted to display into the rrd4j.persist file -instead of just the group:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
timeline* : strategy = everyUpdate, everyMinute
timeline_item_1 : strategy = everyUpdate, everyMinute
timeline_item_2 : strategy = everyUpdate, everyMinute
Remains the nagging feeling that it shouldnāt be necessary as it seems very redundant.
Sorry,
But Iām really busy and I couldnāt make it so far.
Thanks for your answer
maybe Some noob questions,
your help will me more than appreciated . you know the feeling to be close than ever
1. Why do i have a such space (red square)?
Text label="Security" icon="releaselock" {
Frame label="Main" icon="alarm" {
Selection item=HomeStatus icon="home" label="Status" mappings=[bye="Bye",lock="Lock",night="Night",back="Back",door="Door"]
Default item=gpresence_Notification label="Last motion"
//myStr= Z_Door1 + " " +Z_Door1_LastUpdate
Default item=DoorProxy_terrasse label="Terrace [%s]" icon="door"
Default item=Z_Door1_LastUpdate label="Last update" icon="time"
Default item= mqtt_sensor_door label="Entry Door" icon="door"
// Default item= mqtt_sensor_door_LastUpdate label="Last update" icon="time"
Default item= mqtt_sensor_door_LastUpdate1
Default item= mqtt_sensor_door_LastUpdate2
Default item= mqtt_sensor_door_LastUpdate3
Default item= mqtt_sensor_door_LastUpdate4
Default item= mqtt_sensor_door_LastUpdate5
Default item= mqtt_sensor_door_LastUpdate6
Default item= mqtt_sensor_door_LastUpdate7
Default item= mqtt_sensor_door_LastUpdate8
Default item= mqtt_sensor_door_LastUpdate9
Default item= mqtt_sensor_door_LastUpdate10
Webview url="/static/Visualization/Timeline.html?Item=mqtt_sensor_door&ServiceId=influxdb&Hours=12" height=12
Default item=Door_Snooze_Switch label="Door_Snooze_Switch" icon="door"
2. is it possible to change the font color or the X axis (currently black on black?
Guys, any ideas?
Please I would like to see this example! Thanks!!
I want to access a sitemap containing timeline through a nginx reverse-proxy.
The local access āhttp://adress:8080/basicui/app?sitemap=diagnosticā works fine,
but when I try to access this site through a nginx-reverseproxy
āhttps://adress.tld/basicui/app?sitemap=diagnosticā the timline dosnt appear.
Which changes are required to acces timline through a reverseproxy?
