thanks for the fast replay.
I have installed grafana on the same host of openhab and nginx and the service is running.
I can access the startscreen at http://IPadress:3000
But how can I access the BasicUI of openhab ? What config is required for grafana ?
please note, for timeline Im using rrd4j not influx or mysql and my host is a raspi (armV7)
have u had time do do the english documents?
Got it working, excellent, I was trying to load (locally) loader.js and jquery.min.js that just did not work, even with a local copy, that i thought was correct. also reset the base url to my lan ip and port rather than “…/…/”
Thanks for Huge_Go uTube information
Wow! So glad I scrolled further down to find this little gem. Thank you to both of you. This is such an underrated way to display data that honestly should be an integral part of basicUI.
Really cool and working. Unlimited use case useful function .
Trying to use it using tasker . Planning to monitor the app usage in mobile .
Improvements : Duration inside the bar
Should work on mobile app using rest API Currently it is not working over internet .
Currently chart working only on Local net . Internet it is not working .
As long as local htmls don’t get proxied and the html content itself is not public, it wont work remotley. Hopefully there will be something to proxy local htmls safely in the future
excellent tool, I have been tweeking my setups, but one timeline is now not showing entrys against known items, yet the same generation files are working fine on another group of entries.
comments on what would cause this would be appreciated , is it possible the persistence is broken ?
you can always debug in your browser and see if there are any errors coming up. In Firefox press Q and go to console
in the console i found
jquery.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4
also 26 errors of a very long line
found the issue, it appears the persistence i used rrd4j, needs the items persisted individually not via group, yet the visual display needs the items in a group for the purpose of rendering
Is it possible to display a combined multi-axes diagramm and a timeline diagramm sharing the same x-axis scale?
I’m struggling to get the TimeLine shown in the IOS App.
In Safari Browser everything looks good, but in the App I only see a white section.
Is this working for someone?
thanks Stefan
It works for me running the IOS App on a iPhone with IOS13.2.
The autoscaling is bad and it is difficult to make at manual scaling, but it is possible.
Seems the IOS App doesn’t show webview objects due to https I use.
Hi, does anybody have html.zip still? Original is put by author into trash bin - so I cannot download it. Highly appreciate if smbd can post it here (or source code). thnx!
t
\html\Visualization\Timeline.html
<!DOCTYPE html>
<html>
<head>
<Title>Timeline</Title>
<meta http-equiv="X-UA-Compatible" content="IE=Edge">
<link rel="stylesheet" type="text/css" href="../css/visualizationStyle.css">
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js"></script>
<script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>
<!-- https://github.com/evanplaice/jquery-csv -->
<script type="text/javascript" src="../javascript/jquery.csv.min.js"></script>
<script type="text/javascript" src="../javascript/date.js"></script>
<script type="text/javascript" src="../javascript/openHAB.js"></script>
<script type="application/javascript">
var baseURL = "../../../";
var serviceId = "jdbc";
var hours = 24;
//var openHABItemNames = GetGroupItemNames(GetParameter("Group"));
var openHABItemNames = [];
var groupParameter = GetParameter("Group");
var itemParameter = GetParameter("Item");
var hoursParameter = GetParameter("Hours");
var serviceParameter = GetParameter("ServiceId");
if (groupParameter != null) {
if (itemParameter != null) {
openHABItemNames.push(itemParameter);
if (hoursParameter != null) {
var hours = hoursParameter;
if (serviceParameter != null) {
serviceId = serviceParameter;
function filterStateChanges(data) {
var filteredData = [];
for (var i = 0; i < data.length; i++) {
// always keep the 1st entry ...
if (i == 0) {
if (data[i][1] == "ON" || data[i][1] == "OPEN")
filteredData.push(data[i]);
} else {
// only keep transitions ...
if (data[i][1] != data[i - 1][1]) {
return filteredData;
function formatDate(dateObj,format) {
var monthNames = [ "January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December" ];
var curr_date = dateObj.getDate();
var curr_month = dateObj.getMonth();
curr_month = curr_month + 1;
var curr_year = dateObj.getFullYear();
var curr_min = dateObj.getMinutes();
var curr_hr= dateObj.getHours();
var curr_sc= dateObj.getSeconds();
if(curr_month.toString().length == 1)
curr_month = '0' + curr_month;
if(curr_date.toString().length == 1)
curr_date = '0' + curr_date;
if(curr_hr.toString().length == 1)
curr_hr = '0' + curr_hr;
if(curr_min.toString().length == 1)
curr_min = '0' + curr_min;
if(curr_sc.toString().length == 1)
curr_sc = '0' + curr_sc;
if(format == 1)// dd.mm.yyyy HH:mm:ss
return curr_date + "." + curr_month + "." + curr_year + " " + curr_hr + ":" + curr_min + ":" + curr_sc;
else if(format == 2)// yyyy.mm.dd HH:mm:ss
return curr_year + "." + curr_month + "." + curr_date + " " + curr_hr + ":" + curr_min + ":" + curr_sc;
else if(format == 3)// dd/mm/yyyy
return curr_date + "/" + curr_month+ "/" + curr_year;
else if(format == 4)// MM/dd/yyyy HH:mm:ss
return curr_month+ "/" + curr_date + "/" + curr_year + " " + curr_hr + ":" + curr_min + ":" + curr_sc;
function addItemToChart(itemName, hours, serviceId, chartData) {
var openHABItem = GetOpenHABItem(itemName);
var openHABHistoryData = GetOpenHABHistory(itemName, hours, serviceId);
var stateChanges = filterStateChanges(openHABHistoryData);
var label = '';
if ( openHABItem.label != null ) {
label = openHABItem.label;
} else {
label = itemName;
if ( stateChanges.length == 0) {
chartData.addRow([label,'','','opacity: 0',new Date(),new Date()]) //add dummy entry
} else {
for (var i = 0; i < stateChanges.length; i++) {
var entry = [];
entry[0] = label;
entry[1] = '';
entry[3] = null;
entry[4] = new Date(parseInt(stateChanges[i][0]));
if (i + 1 < stateChanges.length) {
entry[5] = new Date(parseInt(stateChanges[++i][0]));
} else {
entry[5] = new Date();
//tooltip
//entry[2] = null;
var duration = Math.trunc((entry[5]-entry[4])/1000);
var hours = parseInt( duration / 3600 ) % 24;
var minutes = parseInt( duration / 60 ) % 60;
var seconds = duration % 60;
var duration_string = seconds + 's';
if (minutes > 0) duration_string = minutes + 'm ' + duration_string;
if (hours > 0) duration_string = hours + 'h ' + duration_string;
entry[2] = '<div class="ggl-tooltip">' +
'<div><strong>' + label + '</strong></div>' +
'<hr>' +
'<table>' +
'<tr><td><span>Start:</span></td><td>' + formatDate(entry[4],1) + '</td></tr>' +
'<tr><td><span>End:</span></td><td>' + formatDate(entry[5],1) + '</td></tr>' +
'</table><hr><table>' +
'<tr><td><span>Duration:</span></td><td>' + duration_string + '</td></tr>' +
'</table>' +
'</div>';
chartData.addRow(entry);
return chartData;
function drawChart() {
var container = document.getElementById("chart");
var chart = new google.visualization.Timeline(container);
var chartData = new google.visualization.DataTable();
chartData.addColumn({
type: 'string',
type: 'string',
type: 'string',
role: 'tooltip',
'p': {'html': true}
type: 'string',
role: 'style'
type: 'date',
type: 'date',
openHABItemNames.forEach(function(itemName) {
chartData = addItemToChart(itemName, hours, serviceId, chartData);
var xAxisFormat = "HH:mm";
if (hours > 24) {
var xAxisFormat = "EEE, HH:mm";
var chartOptions = {
height : window.innerHeight,
/* A theme is a set of predefined option values that work together to achieve
* a specific chart behavior or visual effect. Currently only one theme is available:
* 'maximized' - Maximizes the area of the chart, and draws the legend and
* all of the labels inside the chart area.
theme: 'maximized',
hAxis: {
textPosition: 'in',
format: xAxisFormat,
minValue: (new Date()).addHours(hours * -1),
maxValue: new Date()
tooltip: {
isHtml: true
chart.draw(chartData, chartOptions);
// on document ready ...
$(document).ready(function() {
// load google charts ...
google.charts.load("current", {
packages: ["timeline"]
// set callback ...
google.charts.setOnLoadCallback(drawChart);
</script>
</head>
<body>
<center>
<div id="chart"></div>
</center>
</body>
</html>
hello I tried to get it work but had no luck…so currently I see nothing.
I am using jdbc mariadb persistence and the zip from Mihai_Badea #38 Timeline for Basic UI
But it still displays nothing my sitemap is
Webview url="/static/Visualization/Timeline.html?Group=group_house_doorwindow&ServiceId=jdbc&Hours=24" height=12
I took the one from #48 and everything is fine
Hello to all,
Nice feature to add to the basic ui .
I tried the version from #48 and the following happened to my setup:
- In Chrome I have this warning when I open the page and I can not see the Timeline:
- In Edge I can see the Timeline but I have something missing, maybe an image?
All the help is appreciated.
Additional question if someone knows, is this kind of timeline going to be included in OH3?
Edit: I also experience these errors when I refresh the sitemap in Basic UI:
2020-09-16 12:12:12.712 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:283) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:812) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:549) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:852) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:929) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:250) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:226) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:551) ~[bundleFile:9.4.20.v20190813]
at java.io.OutputStream.write(OutputStream.java:75) ~[?:1.8.0_265]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[bundleFile:?]
at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[bundleFile:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 53 more
Caused by: java.io.IOException: Connection reset by peer
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:1.8.0_265]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:1.8.0_265]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:1.8.0_265]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:501) ~[?:1.8.0_265]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:263) ~[bundleFile:9.4.20.v20190813]
... 53 more
2020-09-16 12:12:18.030 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 53 more
... 53 more
Thank you in advanced for all your help.
Best regards.
