Timeline picker to setup heating, light and so on
Thanks, but Im hoping you can help me more.
I have the time picker in my sitemap by the following line
Frame label="heating Example" {
   Webview url="/static/time-line-picker/index.html?ip=192.168.0.143:8080&transferItem=TransferItem&states=OFF,1,2,3,4&yAxisLabel=1,2,3,4,5,6,7" height=13
when i use http://192.168.0.143:8080/static/time-line-picker/index.html it doesn’t load the picker.
if i just use /static/time-line-picker/index.html it works
And it loads fine, I can select everything and then click accept and sure.
But when i reset the page, the timepicker is back to normal. with the selections not there.
Also, I am running logs in the rule. And the log shows that TransferItem.state is set to NULL.
This is my items file
Group gTimepicker (All)
//Time PIcker
String TransferItem "[%s]"      (gTimepicker)
String SprinklerZone "[%s]"
This is my rules
import org.eclipse.smarthome.model.script.ScriptServiceUtil
import java.util.HashMap
import java.util.ArrayList
// timeline/ timepicker control
// version 0.4
// ToSe
// init values & customize for you own enviroment
// requirements: MapDB
//  String xxxSwitchPoints                   "xxxxxx [%s]"                                               (gTimepicker)
//  Group  gTimepicker        (All)
// data structure
// val HashMap<String,  ArrayList<String>> timePicker = newHashMap(
//     "TransferItem1" -> newArrayList('item1','item2',...)                 // enum all to control
//     "TransferItem2" -> newArrayList('item3')
//     ...        // enum all TransferItems and his
val HashMap<String,ArrayList<String>> timePicker = newHashMap(
    "transferItem"   -> newArrayList('SprinklerZone'))
rule "check switchpoints 1"
//    Time cron "0 0/15 * 1/1 * ? *"
	  Time cron "0/5 * * ? * * *"            // for debug, trigger eatch 15 seconds
    var Number currTimeInterval = ((now.getMinuteOfDay() / 15) + 1).intValue
    var Number currDay = now.getDayOfWeek()
	logInfo("Rule","Running Rule")
    gTimepicker.members.forEach[ currSwitchPlan |
		logInfo("Rule",currSwitchPlan.state.toString)
        if (currSwitchPlan.state !== NULL) {
            var String switchPlan = (currSwitchPlan.state as StringType).toString
            var String currKey = currDay.toString
            // check the differnt week plans 15,17,67; e.g mo-fr, ...
            if (switchPlan.contains('"key":"17"')) currKey = "17"
            if (switchPlan.contains('"key":"15"') && (currDay > 0 && currDay < 6)) currKey = "15"
            if (switchPlan.contains('"key":"67"') && (currDay > 5 )) currKey = "67"
            // determine the scale number in transfer string
            var Number countScale = 1
            var Boolean stopLoop = false
            while ((countScale < 9) && (!stopLoop)) {
                if (switchPlan.contains(countScale.toString + '":')) {
                    if (transform("JSONPATH", "$." + countScale.toString + ".key", switchPlan) == currKey) {
                        countScale = countScale -1
                        stopLoop = true
                    countScale = countScale + 1
                } else {
                    // error in transfer string
                    logError("timepicker","error in transfer string")
                    countScale = (-1)
                    stopLoop = true
            if (countScale != (-1)) {
                var String[] switchPoints = (transform("JSONPATH", "$." + currKey + ".value", switchPlan)).split(',')
                var String[] switchStates = (transform("JSONPATH", "$." + "99", switchPlan)).split(',')
                var ArrayList<String> itemToSwitch = new ArrayList(timePicker.get(currSwitchPlan.name))
                if (!(itemToSwitch.size() == 1 && "".equals(itemToSwitch.get(0)))) {
                    itemToSwitch.forEach [ iTS |
                        var currItem = ScriptServiceUtil.getItemRegistry.getItem(iTS) as GenericItem
                        var newState = switchStates.get(Integer::parseInt(switchPoints.get(currTimeInterval)))
                        // send only commands when current state differenced from new state
                        if (currItem.state.toString != newState) currItem.sendCommand(newState.toString)
rule "manipulate sprinckler"
  Item SprinklerZone changed
  // deactivate all sprinckler zones
  switch ((spricklerZone.type).toString) {
    case "1" : {
      // activate zone 1
	  logInfo("Zone1","Turning on Zone 1")
    case "2" : {
      // activate zone 2
	  logInfo("Zone2","Turning on Zone 2")
    case "3" : {
      // activate zone 3
	  logInfo("Zone3","Turning on Zone 3")
    case "4" : {
      // activate zone 4
	  logInfo("Zone4","Turning on Zone 4")
	case "0" : {
	  // turn off zones
	  logInfo("Zone","Turning off Zones")
I have the HTML Files placed in
openhab2-conf/html/time-line-picker
please tell me what im doing wrong
