@MilosM Thank’s for your feedback and advice. You are solveing this task.
In general i will not change anything in the ruleDSL version of timelinepicker. The javascript version is the future, my time is limited and unfortunately i can’t see how many guys is using the timelinepicker and the various versions. So it’s not so cool, to invest a lot of time for to few installations. (5?, 50?, 300?)
The new v3 is maintained!
Here you will find new features:
switching depending of sunrise and sunset
easer installation (a pretty solution for the token for access on the REST- API is missing but the version is running pretty well)
I posted this infos a few months ago. The interest is pretty limited and i was busy with other things.
Tester and feedback woud be a good idea. Than i can/would update the OP in this thread.
Ok, I was trying to use this updated version. So far no luck. I continue to have the following error:
[WARN ] [b.automation.script.file.RNTs-tlp3.js] - tlp - E002: error in inner loop {}
The API-token has been set to the three files named. Took some detour before reading to use encoding instead of decoding.
Next issue is with the sitemap not showing anything in the windows. Just the windows and some indication of an icon plus the title. I tried with Chrome and Safari.
Any idea how to resolve these issues?
All files have been double and triple checked for its right location. The conf file has been tried and the link in the site map as well.
Ok, long time spend and finally seeing some progress. In Chrome I do see the charts and can change settings. Still there is an issue. When restarting the webpage the graph every time asks for either continue with accepting a change or clear timeline.
The ‘.conf’ file is not in use/empty. Therefore I would expect to set the id in the url together with the name for the linked item. How else would the chart know which item to link to.
What happens, when you refresh the site in your browser? Are you see empty timelines?
You can post the output from the developer console in crome. First refresh the site, set some entrys in the timeline and save this value’s.
I have no clue what made in run the end. After numerous reboots, trying with the paths in the files etc. it suddenly showed the desired info on the Chrome.
Ok, lets come to the error list. For some strange reason I do have Vietnamese fonts only. The software is looking for Robot_Medium.
checked the token between the three files. Its exactly the same in all files.
after pressing save it only says ‘update succeeded’ in switchPointSet jar.js:343
before that it shows
TypeError: Cannot read properties of undefined (reading ‘event’)
at switchPointSet_jsr.js:263:70
switchPointSet_jsr.js:293 TypeError: Cannot read properties of undefined (reading ‘event’)
GET http://192.168.0.5:8080/basicui/fonts/Roboto-Regular.ttf 404 (Not Found)
roboto.css:1 GET http://192.168.0.5:8080/basicui/fonts/Roboto-Medium.ttf net::ERR_ABORTED 404 (Not Found)
tlp_thing_controller.js:29 TypeError: Failed to fetch
at MaterialLayout.init (ripple.js:243:1)
at new MaterialLayout (ripple.js:243:1)
at n (ripple.js:243:1)
at i (ripple.js:243:1)
at Object.o [as upgradeAllRegistered] (ripple.js:243:1)
at ripple.js:243:1
at ripple.js:243:1
at tlp_thing_controller.js:26:11
at new Promise ()
at tlpThing.get (tlp_thing_controller.js:12:12)
at tlp_thing_controller.js:137:16
at new Promise ()
at tlpThing.get_id (tlp_thing_controller.js:134:12)
at Vue._initTimelineView (switchPointSet_jsr.js:234:20)
at Vue.created (switchPointSet_jsr.js:97:10)
at callHook (vue.js:2921:21)
at Vue._init (vue.js:4617:5)
at new Promise ()
at tlpThing.getAll_id (tlp_thing_controller.js:177:31)
at VueComponent._initAdminSetupView (tlpAdminSetup.js:101:16)
at VueComponent.created (tlpAdminSetup.js:87:10)
at new VueComponent (vue.js:4785:12)
at createComponentInstanceForVnode (vue.js:4304:10)
at new Promise ()
at VueComponent._initAdminSetupView (tlpAdminSetup.js:105:18)
at init (vue.js:4125:45)
vue.js:8542 Download the Vue Devtools extension for a better development experience: GitHub - vuejs/devtools: ⚙️ Browser devtools extension for debugging Vue.js applications.
vue.js:8553 You are running Vue in development mode.
Make sure to turn on production mode when deploying for production.
See more tips at Production Deployment — Vue.js
for the token… at first I followed your description going with the decode. There were quite different errors when using this token. So I have to assume when using the correct way for the encrypting of the token and the error messages disappeared that on this end I should be fine.
Used the link you provided for encoding.
Just did the encoding again. Behaviour remains the same.
When encoding there are basically two options. Destination character set is set to UTF8 and destination newline character is set to LF (Unix).
I’m using a RaspberryPi with this two options and it’s works as well.
I still suspect that the thing will not be created and you haven’t access to OH REST-interface.
Perhaps you will send me a pm with your token. After the timeline picker is working you can revoke this token and create a new one.
This is the importend point, when the timeline picker is creating the thing. What can be seen in your console?
