Hi torsten, have you ever considered to implement a binding, similar to the one in the marketplace at this link? I am not an expert at all, so I do not know how difficult it could be.
Every timeline could be a new thing, and the linked item could be a channel, which is sort of what you already do. Configuration could be provided by a string item linked to a configuration channel of the thing.
yes, i have considered how is it easyer to install the timeline picker. My thought is, a binding is not the best approach. It would be possible to install the logic with the binding. But the userinterface is not installable. For this we would need a new widget and at the moment i thing itās a really big challenge to create a complex widget in main UI. (perhaps from me itās missing experience).
An other thought from me is a installation with npm.
But also at this point there is missing experiences to create a package that is published to install.
For this case i think this nessesary:
Install in OH a npm package - This is only in a terminal window possible?
Copy the folders and files in path ā¦/html manually - How can we do this easyer?
Install the server side rule from the marketplace.
Config each timeline in Main UI or in the calling url as parameter.
It would be a lot of work. But is this approach really easyer?
A long, long time ago iām reading thatās possible to create a sitemap inside a rule. Perhaps this could it be much more easyer. Iām looking for a while for it. But iām never find this again.
Can someone point me?
I would say that sitemaps, though still supported in OH 3.X (and probably in OH4), are rather obsolete and it is probably not worth investing in generating them automatically.
It is probably better to offer to OH3 user a way to use the timelinepicker with the OH3 User Interface. There is already a custom widget that displays a timelinepicker into a webframe-card, as it has been described in this thread. The problem is that this webframe card widget needs to be inserted in an overview page and not all users are familiar with widget programming.
I have written a custom list-widget and a custom standalone-card widget that call the webframe card as a popup. In this way, both widgets can be associated to an item inserted in the semantic model and displayed in the UI with minimal knowledge of widget programming. It is not an elegant solution, as parameters need to be entered for each widget (both list and standalone card), but they can be copy/pasted through the XML code. Moreover, I hardcoded my api-key into the custom widget. The first time the widget is clicked, the creation interface appears while the subsequent ones the saved timeline appears. There is no need in this case to initialize the timelinepicker with the custom file. I have not implemented the administration widget but it should be straightforward (at present I use a very simple sitemap)
I do not know if this is similar to what @mjptec is already doing.
If you think that it can be useful I can share my widgets so that someone more knowledgeable may suggest improvements.
When wrapping your widget in a main UI widget, I donāt think it is possible to set the wrapper height based directly on what it contains (I may be wrong and unnecessarily wasting some of my effort), so Iāve set the height automatically based on widget settings. However, this relies on knowing if the auto zoom mode has activated zoom or not.
I used
device.pixelRatio !== 1
in the end, which seems to work but Iāll try to change it to match your useragent check.
This probably counts as getting carried away with minor details! And anyway, I also canāt tell if sunrise mode is activated or a headline exists, which also affect the height.
I hope that sitemaps would be supported also in OH4. Basic UI looks like a little bit old school but itās coverd my wishes much more then Main UI. The designed widgets i have seen are nice but the afford to develop this ones is really high and perhaps iām wrong but the development is in principal try and error. Iām not able to use VSCode and a development runtime.
Please yes. How iām sayd, Main UI is not preferred from me but to stay up to date iām looking for a way to use the new UI.
This looks fine. Iām glad if I can help. The headline will switched with css property display.
The sun releated mode is not switched. In this case there are some additional switches.
uid: widget_timelinepicker
tags: []
props:
parameters:
- description: Titel of your widget
label: Title
required: false
type: TEXT
- description: Unique identifier for your timeline
label: ID
required: true
type: TEXT
- description: OH Rest Token
label: TOKEN
required: true
type: TEXT
- description: Configuration Mode (Default is params, ui)
label: Configuration
required: false
type: TEXT
- description: Days to be managed in your timeline (1,2,3,4,5,6,7 = Each day, 15 = Mon-Fri, 17 = Full Week, 67 = Sat-Sun)
label: Day Configuration
required: true
type: TEXT
- description: States available for your item (Comma-separated list of maximum six states, i.e. 0,15,INCREASE,DECREASE,OFF,ON, ...)
label: Switch States
required: true
type: TEXT
- context: item
description: Item(s) which you want to control with the timeline
label: Linked Item(s)
required: true
type: TEXT
multiple: true
- description: Language for your widget (Default english)
label: Language selection
required: false
type: TEXT
limitToOptions: true
options:
- label: English
value: en
- label: French
value: fr
- label: German
value: de
- label: Italian
value: it
- label: Dutch
value: nl
- label: Portuguese
value: pt
- description: Allows deactivation of timeline in the UI
label: Deactivation button
required: false
type: TEXT
options:
- label: Button active
value: "true"
- label: Button inactive
value: "false"
- description: Zoom mode to enable control slider for mobiles and tablets
label: Zoom mode
required: false
type: TEXT
options:
- label: Automatic zoom
value: auto
- label: Force zoom control
value: force
- label: Disable zoom control
value: no
- description: Colorset for the timeline (Default 1, 2, 3, hex values without hash (i.e. 555E7B,B7D968,B576AD))
label: Colorset
required: false
type: TEXT
- description: Darkmode for the timeline
label: Dark mode
required: false
type: TEXT
options:
- label: Enable dark mode
value: "true"
- label: Disable dark mode
value: "false"
parameterGroups: []
timestamp: Mar 26, 2023, 2:03:32 PM
component: oh-webframe-card
height: 600px
src: ="/static/tlp-jsr/index.html?id=" + props.timeline_id + "&token=" + props.rest_token + "&linkedItems=" + props.linked_Items + "&mode=" + props.mode + "&states=" + props.states + "&lang=" + ((props.language)?props.language:"en") + "&colorset=" + ((props.colorset)?props.colorset:"1") + ((props.deactivation === "true")?"&deactivation":"") + "&zoom=" + ((props.zoom)?props.zoom:"auto") + "&conf=" + ((props.conf)?props.conf:"params") + ((props.dark === "true")?"&dark":"")
title: = props.title
2023-07-30 12:15:04.827 [WARN ] [ore.thing.internal.ThingRegistryImpl] - Cannot create thing. No binding found that supports creating a thing of type 'tlpicker:tlp'.
2023-07-30 12:15:04.884 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'tlpicker:tlp:home' because the thing type was not found in registry.
2023-07-30 12:15:04.887 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'tlpicker:tlp:home' because the thing type was not found in registry.
Hello everyone, @tose thank you very much for your awesome work! This really helps me alot!
But i have see two problems after the installation on OH 4.0.3 first i get a warning as the others already mentioned above:
> 13:17:32.209 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'tlpicker:tlp:home' because the thing type was not found in registry.
The other problem when a take a look at my things i see this:
Itās not so nice but you can ignore the warning and also the ERROR:HANDLER in things.
All data from timelinepicker is stored in thing so you must not install persistance or so what. In previous versions it was nessesary to install Map- persistence, not yet.
Are you useing the javascript version? I think so.
Then you mean that the Thing status is uninitialized you can see the answer 1 post above your original question. Itās okay.
What is with NULL items? Please post a little bit more, so itās not a question and answer game. (e.g. webview url with parameters, can you see something in UI, Main UI or basic)
Then you reload the page with the timelinepicker, is your configured switch points also reloaded in your timeline?
I hope your screenshots are not up to date, its tuesday not monday?
Does this only apply to posts here? You need to put your token in the url.
Your item definitions are not wrong, but completely outdated.
Please compare with my description in the first post in this thread. Where does this old example of the item definition come from?
Hi.
They reload correctly
It was a testā¦ but I have two timelines.
Yes my tokenā¦ hiechTp5Hpā¦
you mean?
Group gTimepicker
Group gTimepickerObserver
String TimelineHelper ā[%s]ā
String TransferItem1 ā[%s]ā (gTimepicker)
