Timeout in Karaf console
I like to keep a SSH session to the Karaf console open with log:tail running. However every 1/2 an hour or so I get thrown out with the following:
[WARN ] [sshd.server.session.ServerSessionImpl] - exceptionCaught(ServerSessionImpl[openhab@/:50946])[state=Opened] InterruptedByTimeoutException: null
I’ve tried changing the sshIdleTimout in /var/lib/openhab2/etc/org.apache.karaf.shell.cfg but it doesn’t seem to have any effect.
Any ideas?
Thanks,
Matt
Same problem here since upgrading to newer version. Might be a setting I’m not sure about.
Same Problem here. Wasn’t able to figure out where it comes from.
ssh to the host and tail -f /var/log/openhab2/*.log
did you restart the OH2 service? I think that changing the sshIdleTimeout will not affect a running service.
another option is to use a SSH client that sends keep alive messages
XshellCore_2017-10-25_22-49-40
That’s not the same thing. A log:tail in karaf gives you the output from both openhab.log and events.log combined. In nice colors!
I have this problem as well. I always ssh into karaf from localhost. In 2.1 I could tail the log forever but after upgrading to 2.2 snapshot I’m thrown out after a while.
OpenHAB restarted & host rebooted.
Ok, I’ve just changed the keepalive settings to send every 60s. Will report back.
No change with keepalive enabled, Karaf console still throws me out.
It’s a change since 2.2, in 2.1 could log in Karaf console and keep log:tail going…
then… this seems to be related to embedded SSHd server (1.6.0) that is included in Karaf 4.1.2
It may be a bug of that component:
openhab> list -s -t 0 | grep sshd
 68 │ Active   │  30 │ 1.6.0                  │ org.apache.sshd.core
openhab> headers 68
Apache Mina SSHD :: Core (68)
Bnd-LastModified = 1498727707328
Build-Jdk = 1.8.0_91
Built-By = gnodet
Created-By = Apache Maven Bundle Plugin
Implementation-Title = Apache Mina SSHD :: Core
Implementation-URL = http://www.apache.org/sshd/sshd-core/
Implementation-Vendor = The Apache Software Foundation
Implementation-Vendor-Id = org.apache.sshd
Implementation-Version = 1.6.0
Manifest-Version = 1.0
Specification-Title = Apache Mina SSHD :: Core
Specification-Vendor = The Apache Software Foundation
Specification-Version = 1.6.0
Tool = Bnd-3.2.0.201605172007
No it’s not a bug!. You should check the userdata folder of openHAB located (for package installations) /var/lib/openhab2/etc and in the file org.apache.karaf.shell.cfg modify the default:
sshIdleTimeout = 1800000
It lets you modify the ssh karaf shell timeout!
:wink:
Did you restart openHAB after the change?
I had the same issue, I modified the value and things are working as planned!
Yes, have both restarted openHAB and rebooted the host.
What build are you using?
2.2.0-SNAPSHOT
Build #1068
Just updated to Build #1070, and rebooted. Testing.
I believe that any OH 2.2.0 Snapshot Build above 1009 will not modify the behavior of the SSHd
S1009 upgraded the Karaf version from 4.0.8 to 4.1.2.
The SSHd is a part of the Karaf shell component and doesn’t get refreshed with the openHAB 2.2 Snapshots.
To get a newer version of the SSHd than the current 1.6.0, you would need to get a newer Karaf bundle upgrade from a future OH 2.2 snapshot release.
(or… you could try to manually deploy a newer version of the SSHd bundle :stuck_out_tongue: )
Another thing to try is:
/etc/openhab2/services/runtime.cfg
org.apache.karaf.shell:sshIdleTimeout = 0
Usually, stuff in the /var/lib/openhab2/etc/ folder get created from parameters that you set in the files contained in the /etc/openhab2/ folders
Since sshIdleTimeout = 1800000 is the default (30 mins)… even if you change this setting in the /var/lib/openhab2/etc/org.apache.karaf.shell.cfg file, the setting will most likely be overwritten with the default value after service restart.
Setting the time out in the /etc/openhab2/ area will make OH2 read that parameter and update both the running config as well as the /var/lib/ files.
openhab> config:list |grep sshIdleTimeout
   sshIdleTimeout = 0
by the way: I tested S1070 also and get the same but much faster than the 30 mins timeout…
I got busted with
17:03:45.946 [WARN ] [sshd.server.session.ServerSessionImpl] - exceptionCaught(ServerSessionImpl[openhab@/0:0:0:0:0:0:0:1:59771])[state=Opened] InterruptedByTimeoutException: null
after about 14mins of logging in via the local ssh shell and issuing log:tail
Exactly the same I’m getting. Clocked 11 minutes here now…
I’m having exactly same issue. 10-15minutes max.
Note that i tried all of the above without any success
Using 2.2.0-SNAPSHOT Build #1073
