Yes it is from the use of the dev-version of the binding and it is the same situation the dump was made. But it is not actually the one the dump was made.
update: Alterco confirmed that this could be related to the firmware. The OS running on the device does not have multi tasking capabilities. Therefore it canât process multiple requests at the same time, which means while sending data (e.g. their cloud or sending http event updates to the App) a REST API request will not be processed, which then leads into a connect timeout. Iâm in discussion with them how to fix this or find a work around. Their recommendation: Use http only to issue commands and Coap to receive status updates, but this requires some extension to their Coap status updates. They confirmed to work on that and have it on the roadmap for version 1.6 - letâs see.
In parallel Iâll include a work around: Retry on connect timeout or connection reset. Not sure if that could be achieved by using HttpUtil or if I need to keep the switch to java.net.HttpURLConnection.
I suppose it should work as well with HttpUtil because the logs did not show anything that should be working completely different with direct JDK http connections. But if itâs needed itâs needed.
how to gwt the info on connect timeout or connection reset from HttpUtil, âTimeoutâ as http response strong is very unspecific, I would also prefer the http response code rather than the response string
Then please use the HttpClientFactory it will give you full access to a managed Jetty client. And Jetty is default implementation for openHAB (HttpUtil uses it internally as well)
Hi @martinvw,
I try to switch to HttpClient. I changed the code, Eclipse doesnât show an error, but when I try to result the dependencies ([Resolve]) I get the following error:
When I run mvn I get
[ERROR] Failed to execute goal org.apache.karaf.tooling:karaf-maven-plugin:4.2.7:verify (karaf-feature-verification) on project org.openhab.binding.shelly: Feature resolution failed for [openhab-binding-shelly/2.5.3.SNAPSHOT]
[ERROR] Message: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-binding-shelly; type=karaf.feature; version=2.5.3.SNAPSHOT; filter:="(&(osgi.identity=openhab-binding-shelly)(type=karaf.feature)(version>=2.5.3.SNAPSHOT))" [caused by: Unable to resolve openhab-binding-shelly/2.5.3.SNAPSHOT: missing requirement [openhab-binding-shelly/2.5.3.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.binding.shelly; type=osgi.bundle; version="[2.5.3.202003122105,2.5.3.202003122105]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.binding.shelly/2.5.3.202003122105: missing requirement [org.openhab.binding.shelly/2.5.3.202003122105] osgi.wiring.package; filter:="(&(osgi.wiring.package=io.netty.handler.codec.http)(version>=4.1.0)(!(version>=5.0.0)))"]]
[ERROR] Repositories: {
[ERROR] file:/Users/markus/Dev/openhab-2-5-x/git/openhab-addons/bundles/org.openhab.binding.shelly/target/feature/feature.xml
[ERROR] mvn:org.apache.karaf.features/framework/4.2.7/xml/features
[ERROR] mvn:org.apache.karaf.features/standard/4.2.7/xml/features
[ERROR] mvn:org.openhab.core.features.karaf/org.openhab.core.features.karaf.openhab-core/2.5.0/xml/features
[ERROR] mvn:org.openhab.core.features.karaf/org.openhab.core.features.karaf.openhab-tp/2.5.0/xml/features
[ERROR] mvn:org.ops4j.pax.web/pax-web-features/7.2.11/xml/features
[ERROR] }
I checked other bindings, but canât find additional dependencies for feature.xml, pom.xml etc.
I added the following to the HandlerFactory and Discovery handler
import org.eclipse.jetty.client.HttpClient;
import org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory;
public class ShellyHandlerFactory extends BaseThingHandlerFactory {
private @Nullable HttpClient httpClient;
@Reference
protected void setHttpClientFactory(HttpClientFactory httpClientFactory) {
this.httpClient = httpClientFactory.getCommonHttpClient();
protected void unsetHttpClientFactory(HttpClientFactory httpClientFactory) {
this.httpClient = null;
also adding @Reference HttpClient httpClient to the injected constructorâs parameter list doesnât work.
Any idea?
Do you have the branch pushes somewhere? Does it work in Maven?
Did you add them to feature.xml:
I would expect the transport-http like in: https://github.com/openhab/openhab-addons/blob/88c489091862784167ce0880c4fbde2d8a0b6c0c/bundles/org.openhab.binding.spotify/src/main/feature/feature.xml
those are my dependencies
<feature name="openhab-binding-shelly" description="Shelly Binding" version="${project.version}">
<feature>openhab-runtime-base</feature>
<feature>openhab-transport-http</feature>
<feature>openhab-transport-coap</feature>
<feature>openhab-transport-mdns</feature>
<bundle start-level="80">mvn:org.openhab.addons.bundles/org.openhab.binding.shelly/${project.version}</bundle>
</feature>
My repo ist here (branch shelly_snapshot)
@martinvw I checked my CarNet binding, which is under development. There I also use jetty httpClient and event donât have openhab-transport-http in feature.xml
I must admit that I didnât develop bindings from scratch so I did not have to work with such things that often. Maybe one of the other guys knows maybe @J-N-K, @wborn or @hilbrand? Thanks
just found out that it works without the org.openhab.transport-http line - he he
grr, after debuggung was finised (everything is working fine) I tried to generate a new jar and hit the same thing (at least loiks like that):
[ERROR] Message: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-binding-shelly; type=karaf.feature; version=2.5.3.SNAPSHOT; filter:="(&(osgi.identity=openhab-binding-shelly)(type=karaf.feature)(version>=2.5.3.SNAPSHOT))" [caused by: Unable to resolve openhab-binding-shelly/2.5.3.SNAPSHOT: missing requirement [openhab-binding-shelly/2.5.3.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.binding.shelly; type=osgi.bundle; version="[2.5.3.202003151920,2.5.3.202003151920]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.binding.shelly/2.5.3.202003151920: missing requirement [org.openhab.binding.shelly/2.5.3.202003151920] osgi.wiring.package; filter:="(&(osgi.wiring.package=io.netty.handler.codec.http)(version>=4.1.0)(!(version>=5.0.0)))"]]
[ERROR] }
[ERROR] Resources: {
[ERROR] mvn:com.eclipsesource.jaxrs/publisher/5.3.1
[ERROR] mvn:com.google.guava/failureaccess/1.0.1
[ERROR] mvn:com.google.guava/guava/18.0
[ERROR] mvn:com.google.guava/guava/27.1-jre
[ERROR] mvn:commons-codec/commons-codec/1.6
[ERROR] mvn:commons-collections/commons-collections/3.2.1
[ERROR] mvn:commons-io/commons-io/2.2
[ERROR] mvn:commons-lang/commons-lang/2.6
[ERROR] mvn:commons-net/commons-net/3.3
[ERROR] mvn:de.jollyday/jollyday/0.5.8
[ERROR] mvn:de.maggu2810.p2redist/com.google.inject/3.0.0.v201312141243
[ERROR] mvn:de.maggu2810.p2redist/org.antlr.runtime/3.2.0.v201101311130
[ERROR] mvn:javax.annotation/javax.annotation-api/1.2
[ERROR] mvn:javax.annotation/javax.annotation-api/1.3
The HttpClientFactory
is provided by the org.openhab.core.io.net
bundle for which you donât need any additional feature dependencies.
It might work better if you also use constructor injection for the HttpClientFactory
not the HttpClient
. Itâs impossible to inject the HttpClientFactory
into the ShellyHandlerFactory
using the setter before it has been created using the constructor.
ok, inserted HttpClientFactory in the HandlerFactoryâs contructor, this works
Does the MDNSDiscoveryParticipant also supports constructor injetion?
Whatâs about a HttpServlet?
public class** ShellyEventServlet extends HttpServlet {
does this also also supports constructor injection?
Nevertheless mvn still reports the error:
[ERROR] Message: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-binding-shelly; type=karaf.feature; version=2.5.3.SNAPSHOT; filter:="(&(osgi.identity=openhab-binding-shelly)(type=karaf.feature)(version>=2.5.3.SNAPSHOT))" [caused by: Unable to resolve openhab-binding-shelly/2.5.3.SNAPSHOT: missing requirement [openhab-binding-shelly/2.5.3.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.binding.shelly; type=osgi.bundle; version="[2.5.3.202003152148,2.5.3.202003152148]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.binding.shelly/2.5.3.202003152148: missing requirement [org.openhab.binding.shelly/2.5.3.202003152148] osgi.wiring.package; filter:="(&(osgi.wiring.package=io.netty.handler.codec.http)(version>=4.1.0)(!(version>=5.0.0)))"]]
[ERROR] }
[ERROR] mvn:javax.el/javax.el-api/3.0.0
[ERROR] mvn:javax.mail/mail/1.4.7
[ERROR] mvn:javax.measure/unit-api/1.0
[ERROR] mvn:javax.servlet/javax.servlet-api/3.1.0
[ERROR] mvn:javax.validation/validation-api/1.1.0.Final
I donât get why this was no problem in my CarNet binding
It should work for anything that is instantiated using the @Component
annotations.
Thatâs because you should use the jetty instead of the netty import in ShellyHttpApi.
The computer will be very happy if you switch it to:
import org.eclipse.jetty.http.HttpMethod;
top, this works. You made my day!
also switched DiscoveryParticipant and Servlet to instric constructors. Nice side effect:
- makes the code more stable (pointer might not be null = no NPE)
- allows to turn @Nullable instance variables to final, because they get initialized in the constructor and not asynchronously, which also means
- reduced number of @Nullable and @SuspressWarnig(ânullâ) annotations
= improve stability, reduced code, code better readable, less review efforts
This think the topic constructor injection should be explained and recommended in the coding guidelines. It should also become a formal criteria for acceptance of OH3 bindings.
PacMan: great job
Nice! Yes the constructor injection is preferred over setters for all those reasons. The only downside is readability (or potential cycles) when a lot of dependencies are injected. But when thatâs the case the class usually has too many responsibilities.
for me looks good and readability is way better than before, because I could remove various @Nullable.
