Dunno. What makes you think the error is that piece of code? The code shown is incomplete, missing } and ] and ).
@rossko57 sorry I already posted the code in my first post. The brackets are all there, There is no general issue message that sth. in the code is wrong thatswhy I assume that it is related to the number format.
here the code:
var Timer Lichtweckertimer = null
rule "Schlafzimmer morning alarm Radio"
Item Lichtwecker_Osram changed
if(Lichtwecker_Osram.state == ON) {
var Number sollMinuten // define var
if(Lichtschlauch_Wecker_H.state instanceof Number) // check if value valid
sollMinuten = (Lichtschlauch_Wecker_H.state as Number).intValue * 60 // set var
else
sollMinuten = -61 // mark as invalid
if(Lichtschlauch_Wecker_M.state instanceof Number) // check if value valid
sollMinuten = sollMinuten + (Lichtschlauch_Wecker_M.state as Number).intValue // set var
else
sollMinuten = -1 // mark as invalid
if (sollMinuten >= 0 ) { // check if time valid
Lichtweckertimer?.cancel
logInfo("Test0", "T0 {}",sollMinuten) // cancel existing timer
if (sollMinuten <= (now.getHour * 60 + now.getMinute)){
logInfo("Test1", "T1 {}:{}",sollMinuten, (now.getHour * 60 + now.getMinute))
sollMinuten = 1440 - (now.getHour * 60 + now.getMinute ) + sollMinuten }
else {
sollMinuten = sollMinuten - ( now.getHour * 60 + now.getMinute )
logInfo("Test2", "T2")}
logInfo("Test3", "T3 {}",sollMinuten)
Lichtweckertimer = createTimer(now.plusMinutes(sollMinuten.longValue) , [|
if((ZigLightstrip_2.state as Number) < 91 && (ZigLight1_Dimmer.state as Number) < 91) { // check Level
ZigLightstrip_2.sendCommand((ZigLightstrip_2.state as Number) + 10)
ZigLight1_Dimmer.sendCommand((ZigLight1_Dimmer.state as Number) + 10) // Increase Level by 10 fĂŒr deckenfluter und bettlicht
Lichtweckertimer.reschedule(now.plusMinutes(1)) // Reschedule Timer
} else { // or
Lichtwecker_Osram.sendCommand(OFF) // switch Wecker off
logInfo("morningAlarm", "Wakeup finished")
if (Sonos_Radio_Wecken.state == ON) {
timer_Sonos_WakeUp?.cancel
timer_Sonos_WakeUp = createTimer(now.plusSeconds(5),[|
Sonos_ONE1_Volume.sendCommand(10)
Sonos_ONE1_TuneInID.sendCommand("24878")
logInfo("morningAlarm", "Wecker erstellt fĂŒr {}:{} Uhr",Lichtschlauch_Wecker_H.state,Lichtschlauch_Wecker_M.state)
} else {
logWarn("morningAlarm", "Stunde oder Minute haben keinen gĂŒltigen Wert!")
} else {
logInfo("morningAlarm", "Wecker ausgeschaltet")
Ignore the LogInfo âTestsâ they are just for me understanding what value âSollMinutenâ is at a specific stage.
Sorry again that I did not send the code completely.
Kindly,
Woogi
Yes, but youâve changed it since then.
Not at all - thatâs what theyâre for, following the path and showing the values.
Errors in Timer code are often unhelpful, this one very much in that category.
We can make some deductions thoughâŠ
From the log timestamp 14:41:57.457
to the WARN timestamp 14:43:57.443
is two minutes, so it looks like your Timer was set up okay and executed when expected. The problem lies within the code being executed.
This looks suspiciously like something is trying to parse a number from text, but doesnât understand a German language decimal â,â
You could add some more logInfo() to see where it gets to before the error. My guess is one or both of those sendCommand().
DSL can be picky about sending objects, even numbers, as commands. Safe way is to send the string version.
ZigLightstrip_2.sendCommand(((ZigLightstrip_2.state as Number) + 10).toString)
Maybe ZigLightstrip_2 isnât a Dimmer Item at all but of type Color? Color would have a , in the statusâŠ
Iâm having a similar issue as the OP, so rather than creating a new topic I thought Iâd add to this one.
This is the error I get, which is the same as the OP received. Having looked at all of the replies I donât see a valid solution to the issue.
An error occurred during the script exe
cution: Could not invoke method: java.time.ZonedDateTime.plusMinutes(long) on instance
This is part of the rule I have in place that is causing the above error.
createTimer(now.plusMinutes(Random_FifteenMinutes.state as Number).intValue) [|
Announcement_Type.postUpdate(1)
For completeness here is how I have the item defined.
Number Random_FifteenMinutes "[%d Minutes]" <time>
I have tried all the different combinations mentioned in the topic and still havenât managed to get this rule working as it should. My assumption is that the Number stored in the item is a Decimal and I need it to be an Integer for the rule to work as it should, but clearly havenât found the right syntax to us and need some help.
Thanks,
Garry
Careful with the brackets - that is trying to get the intValue of plusMinutes
OK, thanks for that information. So how do I resolve my issue as clearly I have the wrong syntax and not getting any closer to finding the answer.
Break it down.
(now.plusMinutes
.intValue)
If we simplify this as written by hard coding the value from the Item to 5 it would be:
now.plusMinutes(5).intValue
That doesnât make sense, a ZonedDateTime doesnât have an intValue
. You want to pass the intValue
to plusMinutes
You want
(now.plusMinutes
or
(now.plusMinutes((Random_FifteenMinutes.state as Number).intValue))
Or another way to break it down:
val randState = Random_FifteenMinutes.state
val randNum = randState as Number
val randInt = randNum.intValue
now.plusMinutes(randInt)
Or a little less broken down
val rand = (Random_FifteenMinutes.state as Number).intValue
nhow.plusMinutes(rand)
Thanks @rlkoshak as all ways a very detailed explanation. Iâve gone with the below syntax and itâs working just as I hoped.
