- Platform information:
- Hardware: Virtualised 64bit CPU
- OS: Ubuntu 18.04
- Java Runtime Environment: openjdk version “1.8.0_232”
- openHAB version: openHAB 2.4.0 Release Build
I have a rule here that doesn’t seem to be triggering and I can’t be sure if the problem is with the rule or with the thermostat. I am leaning towards the thermostat because of the way it presents it’s setpoint to OH.
The rule is here:
rule “Heat Boots Timer”
Item thermostat_gf_setpoint changed
if(thermostat_gf_setpoint.state > 21)
if(boostTime===null)
switch_gf_hall_heatboost.sendUpdate(ON)
boostTime = createTimer(now.plusMinutes(60)) [|
thermostat_gf_serpoint.sendCommand(20)
switch_gf_hall_heatboost.sendUpdate(OFF)
boostTime = null
The problem I see from the device side is how it presents it’s data, looking at the logs it seems that the °C is included in the state. It also seems to have an odd setpoint (2E+1). Here are some logs from changing the setpoint.
2020-01-20 12:18:13.557 [ome.event.ItemCommandEvent] - Item 'thermostat_gf_setpoint' received command 21
2020-01-20 12:18:13.560 [nt.ItemStatePredictedEvent] - thermostat_gf_setpoint predicted to become 21
2020-01-20 12:18:13.568 [vent.ItemStateChangedEvent] - thermostat_gf_setpoint changed from 2E+1 °C to 21.0 °C
2020-01-20 12:18:15.387 [ome.event.ItemCommandEvent] - Item 'thermostat_gf_setpoint' received command 22
2020-01-20 12:18:15.390 [nt.ItemStatePredictedEvent] - thermostat_gf_setpoint predicted to become 22
2020-01-20 12:18:15.398 [vent.ItemStateChangedEvent] - thermostat_gf_setpoint changed from 21.0 °C to 22.0 °C
2020-01-20 12:18:17.906 [ome.event.ItemCommandEvent] - Item 'thermostat_gf_setpoint' received command 20
2020-01-20 12:18:17.911 [nt.ItemStatePredictedEvent] - thermostat_gf_setpoint predicted to become 20
2020-01-20 12:18:17.920 [vent.ItemStateChangedEvent] - thermostat_gf_setpoint changed from 22.0 °C to 20.0 °C
2020-01-20 12:18:19.153 [ome.event.ItemCommandEvent] - Item 'thermostat_gf_setpoint' received command 19
2020-01-20 12:18:19.157 [nt.ItemStatePredictedEvent] - thermostat_gf_setpoint predicted to become 19
2020-01-20 12:18:19.166 [vent.ItemStateChangedEvent] - thermostat_gf_setpoint changed from 20.0 °C to 19.0 °C
If anyone could point me in the right direction, whether this is correcting an error in the rule or changing the systax to reflect how the item state is reported I’d be grateful.
Thanks in advance
Fred.
