Very sorry for my late reply.
I’m afraid I did nor do have a lot more than this.
I use habpanel.
Let me know if that answers more or less your question?
Best regards
Raf
I use habpanel.
Best regards
Raf
ok, I’ll give it one more try ![]()
I realize this is an old post, but found @Raf_Daems starter code helpful and was able to setup the necessary working code to accomplish a simple timer for my concrete heater. You will notice, that in most ways the code is unchanged from that provided in Jul '18, but included the items definitions in case that helps other noobs like myself.
Item Definition in a file called mqtt.items:
Switch Concrete_Heater "Concrete Heater" <snow> (Actuation, gGar) {channel="mqtt:topic:MQTTBroker:T71:switch"}
String conc_heater_countdown "Concrete Heater Countdown Timer [%s]" <time> (Actuation, gGar)
Number conc_heater_count "Concrete Heater Countdown Timer (seconds)"
Switch conc_heater_countdownRunning
Switch conc_heater_countdownReset
Switch conc_heater_countdownKeeprunning
Switch conc_heater_countdownStart
Rule Definition within a file called conc_heater.rules
var Integer conc_heater_startvalue = 7200 //starting timer value in seconds
rule "Initialize concrete heater countdown timer"
System started
if (conc_heater_countdownRunning.state == NULL) conc_heater_countdownRunning.postUpdate(OFF)
if (conc_heater_countdownReset.state == NULL) conc_heater_countdownReset.postUpdate(OFF)
if (conc_heater_countdownKeeprunning.state == NULL) conc_heater_countdownKeeprunning.postUpdate(OFF)
if (conc_heater_countdownStart.state == NULL) conc_heater_countdownStart.postUpdate(OFF)
if (conc_heater_count.state == NULL) conc_heater_count.postUpdate(conc_heater_startvalue)
rule "Start countdown when concrete heater is turned on"
Item Concrete_Heater changed to ON
if (conc_heater_countdownStart.state == ON) {
logInfo("Concrete heater countdown timer","Restart timer")
conc_heater_countdownReset.postUpdate(ON)
if (conc_heater_countdownStart.state == NULL) {
logInfo("Concrete heater countdown timer","Start timer")
conc_heater_countdownStart.postUpdate(ON)
if (conc_heater_countdownStart.state == OFF) {
rule "Stop countdown when concrete heater is turned off"
Item Concrete_Heater changed to OFF
if (conc_heater_countdownStart.state == ON) conc_heater_countdownStart.postUpdate(OFF)
rule "Concrete heater countdown timer running"
Item conc_heater_countdownStart changed to ON
or
Item conc_heater_countdownKeeprunning changed to ON
or
Item conc_heater_countdownReset changed to ON
//if(1==1) //formatting and outputting count to stringToSend
logInfo("Concrete heater countdown timer","formatting and outputting count to stringToSend --> concrete heater countdown timer")
var sec = (conc_heater_count.state as Number).intValue % 60
var min = (((conc_heater_count.state as Number).intValue) / 60) % 60
var hrs = (((conc_heater_count.state as Number).intValue) / (60*60)) % 24
var day = ((conc_heater_count.state as Number).intValue) / (60*60*24)
var String stringToSend
if ( conc_heater_count.state > 86400)
stringToSend = String::format("%1$02d days, %2$02d:%3$02d:%4$02d", day, hrs, min, sec)
else
stringToSend = String::format("%1$02d:%2$02d:%3$02d", hrs, min, sec)
conc_heater_countdown.postUpdate (stringToSend)
if (conc_heater_countdownStart.state == ON) //Start is ON
logInfo("Concrete heater countdown timer","Start is on")
if ((conc_heater_count.state as Number).intValue > 0 && conc_heater_countdownReset.state==OFF)
logInfo("Concrete heater countdown timer","Countdown value in seconds: " + conc_heater_count.state.toString)
createTimer(now.plusSeconds(1), [ |
if (conc_heater_countdownStart.state == ON) //if start is STILL on this second later
logInfo ("Concrete heater countdown timer","((conc_heater_count.state as Number).intValue > 0 && countdownReset.state==OFF)")
conc_heater_count.postUpdate((conc_heater_count.state as Number).intValue -1)
conc_heater_countdownKeeprunning.postUpdate(ON)
if (conc_heater_countdownReset.state==ON)
logInfo("Concrete heater countdown timer","if (countdownReset.state==ON)")
conc_heater_countdown.postUpdate("resetting")
conc_heater_count.postUpdate (conc_heater_startvalue)
if ((conc_heater_count.state as Number).intValue == 0)
logInfo("Concrete heater countdown timer"," if ((count.state as Number).intValue == 0)")
rule "Cleaning up concrete heater countdown timer"
Item conc_heater_countdownStart changed to OFF
logInfo("Concrete heater countdown timer"," Item countdownStart changed to OFF")
conc_heater_countdown.postUpdate ("timer stopped")
logInfo("Concrete heater countdown timer","Stop timer and turn off concrete heater")
Concrete_Heater.sendCommand(OFF)
Very simple, when the concrete heater is turned on, it will start a 7200sec timer (2hr) and display a string of the countdown just below the concrete heater switch in my UI. The heater is turned off when the timer reaches 0.
