Hey all,
I have a rule where I tell OH that I’m going to bed. It turns off a bunch of stuff then plays two audio files
The first is a basic “good night - the house is in night mode” type message
Then the script looks for open doors. If there are none- It says “All doors are closed” if there are is tells me what doors are open.
So, I’m trying to play two audio files back to back. What I found is that they just play over one another making it not possible to understand them.
I had been using two executeCommandLine() commands and playing through an external command, but I spent some time to convert over to the playSound() command and it does the same thing.
Basically what I resorted to is putting in a 3 second sleep between the commands:
Thread::sleep(3000)
Is there another way to do this? I’m worried that sometimes the 3 seconds might not be enough.
