I have TKB TZ77 running with OH 2.4 and it appears that the channels in zwave DB are not correct.
- Color_color is not working.
Trying to use item:
Color LED_Strip_Bottom_Color "Kitchen bottom LED strip" <colorlight> (Kitchen) { channel="zwave:device:16160425003:node16:color_color" }
gives following warning:
2019-01-19 12:01:10.988 [ome.event.ItemCommandEvent] - Item 'LED_Strip_Bottom_Color' received command 0,0,64
2019-01-19 12:01:10.997 [nt.ItemStatePredictedEvent] - LED_Strip_Bottom_Color predicted to become 0,0,64
19-Jan-2019 12:01:11.003 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 16: Command received zwave:device:16160425003:node16:color_color --> 0,0,64 [HSBType]
19-Jan-2019 12:01:11.006 [WARN ] [nding.zwave.internal.converter.ZWaveColorConverter] - NODE 16: Unknown color mode null.
19-Jan-2019 12:01:11.009 [DEBUG] [nding.zwave.internal.converter.ZWaveColorConverter] - NODE 16: Converted command '0,0,64' to {} for channel = zwave:device:16160425003:node16:color_color, endpoint = 0.
So it seems that “colorMode=RGB” is missing from the DB. Could this be updated ?
- Color_temperature is defined but I believe not supported by this device.
Zvvave DB has this channel definition:
<channel id="color_temperature" typeId="color_temperature">
<label>Color Temperature </label>
<properties>
<property name="binding:*:PercentType">COMMAND_CLASS_SWITCH_COLOR;colorMode=DIFF_WHITE</property>
<property name="binding:Command:OnOffType">COMMAND_CLASS_SWITCH_MULTILEVEL;</property>
</properties>
</channel>
However, as implemented in zvawe binding ZwaveColorConventer:
} else if ("DIFF_WHITE".equals(channel.getArguments().get("colorMode"))) {
PercentType color = (PercentType) command;
// Queue the command
int value = scaleColor(color);
colors.put(ZWaveColorType.COLD_WHITE, 255 - value);
colors.put(ZWaveColorType.WARM_WHITE, value);
It cannot work since device is not RGB+CT, just RGBW - does not have COLD_WHITE channel to set.
- Device picture is not correct:
Correct picture:
Device zwave DB link
My device XML:
network_0184d27f__node_16.xml (16.6 KB)
BR/Łukasz
