Log are always a problem but also a god send when you need them.
So I have installed ZRAM with the default config. So to save any confusion of where this config now is:
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 15G 3.2G 11G 23% /
devtmpfs 484M 0 484M 0% /dev
tmpfs 488M 0 488M 0% /dev/shm
tmpfs 488M 6.6M 482M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 488M 0 488M 0% /sys/fs/cgroup
overlay1 575M 2.7M 530M 1% /var/lib/openhab2
tmpfs 100M 248K 100M 1% /tmp
/dev/mmcblk0p1 42M 23M 19M 55% /boot
/dev/zram1 575M 2.7M 530M 1% /opt/zram/zram1
/dev/zram2 469M 18M 416M 5% /opt/zram/zram2
overlay2 469M 18M 416M 5% /var/log
tmpfs 98M 0 98M 0% /run/user/1000
/etc/fstab:
proc /proc proc defaults 0 0
PARTUUID=529e9566-01 /boot vfat defaults 0 2
PARTUUID=529e9566-02 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
tmpfs /tmp tmpfs nosuid,nodev,size=100m 0 0
# tmpfs /var/log/openhab2 tmpfs nosuid,nodev 0 0
# tmpfs /var/tmp tmpfs nosuid,nodev 0 0
/usr/share/openhab2 /srv/openhab2-sys none bind 0 0
/etc/openhab2 /srv/openhab2-conf none bind 0 0
/var/lib/openhab2 /srv/openhab2-userdata none bind 0 0
/var/log/openhab2 /srv/openhab2-logs none bind 0 0
/usr/share/openhab2/addons /srv/openhab2-addons none bind 0 0
/etc/ztab:
# swap alg mem_limit disk_size swap_priority page-cluster swappiness
swap lz4 200M 600M 75 0 90
# dir alg mem_limit disk_size target_dir bind_dir
dir lz4 200M 600M /var/lib/openhab2 /openhab2.bind
# log alg mem_limit disk_size target_dir bind_dir oldlog_dir
log lzo 150M 500M /var/log /log.bind
PLEASE NOTE THIS IS NOT ME SAYING THIS IS RIGHT.
