Platform information:
Hardware: Raspberry Pi 4
OS: openHABian
openHAB version: OpenHAB 2.5
Issue of the topic: I want to change the WiFi network of the openHAB, I don’t know where to edit it.
Please do help on the issue
OS: openHABian
Login to your Raspberry
SUDO openhabian-config
30 - System Settings
36 - WiFI Setup
I just tested this way, but it won’t work, as OP is using a Pi4(as me). I got an error-message.
Dont know what kind of error message you get, but try to change the file manually. You must be ROOT!
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
If you allready have a wifi connected, there should be the current settings.
Change them to your new settings.
br
demlstda, I just installed openhabian on a PI 4, openhabian-config 30,36 doesn’t work, error message says this function is for PI 3 so not designed for PI 4. I changed the config file before initial setup with SSID and Password but it still doesn’t work.
For anyone else who is having trouble with changing the network, I may have a solution. I was having similar problems moving my OpenHABian RPi4 to a new network recently. openhabian-config didn’t seem to actually work, even though /etc/wpa_supplicant/wpa_supplicant.conf showed the new network SSID and password. Router did not show the RPi on the network, and I still couldn’t ping any local or internet addresses.
I ran sudo comitup-cli and was able to select a network and input the password. This seems to have worked. The device is now visible to my router, and I am able to ping internet addresses. Though for some reason, the OpenHABian welcome display still shows the old network’s IP address. Not sure if there’s a way to fix that…
