Hi everyone
I get the following error when starting openHAB:
2020-01-01 14:49:41.627 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Strom.rules', using it anyway:
The method withDayOfMonth(int) from the type DateMidnight is deprecated
The method toDateMidnight() from the type DateTime is deprecated
The method plusMonths(int) from the type DateMidnight is deprecated
2020-01-01 14:49:41.631 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Strom.rules'
Here is my setup:
openhabian installed on Raspberry Pi 4 Model B
Raspbian GNU/Linux 10 (buster)
Linux 4.19.75-v7l+
openHAB 2.5.0-1 (Release Build)
InfluxDB v1.7.9
Strom.rules
rule "Stromverbrauch+Kosten aktueller Monat+Prognose"
Time cron "35 */10 * * * ?" //alle 10 Minuten zur 35. Sekunde
//Aktuell
var Number vStromPreis180 = StromPreis180.state
var Number vKWHumrechnung = 3600000
var Number vStrom = ZaehlerStromTarif0.state //mit kWh
vStrom = vStrom / vKWHumrechnung //ohne kWh
var Number vStromHistory = (ZaehlerStromTarif0.historicState(now.toDateMidnight.withDayOfMonth1), "influxdb").state as DecimalType) //History Wert Mitternacht zum Monatswechsel
var Number vStromThisM = vStrom - vStromHistory
var Number vStromKostenThisM = vStromThisM * vStromPreis180 / 100
postUpdate(ZaehlerStromThisM, vStromThisM)
postUpdate(ZaehlerStromKostenThisM, vStromKostenThisM)
//Prognose
var Number TimestampManfang = now.toDateMidnight.withDayOfMonth(1).millis
var Number TimestampMende = now.toDateMidnight.withDayOfMonth(1).plusMonths(1).millis
var Number SecondOfMonth = (now.millis - TimestampManfang ) / 1000 //aktuelle Sekund des Monats
var Number SekundenImM = (TimestampMende - TimestampManfang) / 1000 //Anzahl derSekunden des Monats
var Number vZaehlerStromThisM = ZaehlerStromThisM.state //mit kWh
vZaehlerStromThisM = vZaehlerStromThisM / vKWHumrechnung //ohne kWh
var Number vZaehlerStromThisMp = vZaehlerStromThisM * SekundenImM / SecondOfMonth
var Number vZaehlerStromKostenThisMp = vZaehlerStromThisMp * vStromPreis180 / 100
postUpdate(ZaehlerStromThisMp, vZaehlerStromThisMp)
postUpdate(ZaehlerStromKostenThisMp, vZaehlerStromKostenThisMp)
The rule works great. What do I have to change so that the error message no longer comes?
thx
