Too Many MQTT Brokers?
I am lost and confused regarding my standalone MQTT broker. It is possible that I have 2 defined by mistake, as I changed the keep alive from 60000 to 180000 and it had no effect.
All broker configs done via PaperUI. Screen shots follow. If more detail is required, I can do that.
“System broker” is purely for management connection to the embedded MQTT broker option. If you use any other broker, you don’t want it.
Problem solved. No clue how or when the “manage system broker” got into my system, but removing it seems to have cleared the remaining broker issues.
THANKS!!!
