Tool that auto-creates items file for a thing's channels
implementing the leading string for the label will be easy. give me some time :wink:
interessting. didn’t even know anything about HABapp. what are the key features you use it for?
I am assuming you mean HABApp, not the feature to create and link items automatically.
Currently I am doing all my automation for two openhab instances through HABApp.
I really like coding in python3 and for me doing it in HABApp is way quicker and less error prone than the normal jsr223 rule engine.
Also as mentioned I also use it to share z-wave configuration parameters across similar things so they all behave the same.
Additionally I use it to link mqtt to my openhab instances.
@Spaceman_Spiff check out the new version
Hi all, I’ve updated the code to support openHAB 3 authorization via API Token
Very Nice, I’ll be updating this tonight when I get home.
Very nice, Was wondering about this when I moved to V3. I had added it to a list of things to play with. Great work.
I absolutely love this. However I did just update to 4.1.2 from 3.4.xx. I currently am getting an error
“Calling openHAB REST API failed! ->Not Found”
I have not dug into this yet. I did not see any update on the github page. Will this work with the changes in 4.x? Thoughts?
Edit:
I found a patch for this waiting for a Pull request. The Patch appear to work just fine with V4. I no longer have a V3 system setup to test backwards compatibility tho.
I noted that the patch appears to work fine. I ended up forking, and probably going to make some changes as well for my own use. Posting the fork if it helps anybody else who comes looking for this same problem. Thanks to Bloodboy1986 for the V4 Rest API Patch as well.
https://github.com/dotelpenguin/openHAB_ItemCreator
