Torque OBDII Vehicle integration
OK here is the flow. the simple part is receiving the get.
The HTTP in node splits out the data and the HTTP out node gives the “OK!” the torque app is looking for.
I also have a write to MySQL to store the data. that can be removed if youonly want to see it real time or have openHAB do the logging.
In torque under Settings > Data Logging and Upload
Select what to log = All the PID’s you want to sent to node-red
Upload to web server = checked
Webserver URL = http://your.nodered.server:1880/torque/
let me know if you have any more questions.
        "id": "2ce0055.8743efa",
        "type": "tab",
        "label": "Torque",
        "disabled": false,
        "info": ""
        "id": "67436221.b54c0c",
        "type": "http in",
        "z": "2ce0055.8743efa",
        "name": "",
        "url": "/torque",
        "method": "get",
        "upload": true,
        "swaggerDoc": "",
        "x": 221,
        "y": 143,
        "wires": [
                "f98f22cc.807ba",
                "557d7766.022168",
                "33d571b3.db242e",
                "69b56cf.77bc694",
                "683933fa.d76f1c",
                "ab2ff853.e8b808",
                "c005b8b1.f06b98",
                "96abaa53.c70988",
                "ee5bc723.594bf8",
                "dfdc4763.7a8fd8",
                "cee9fa09.98b6d8",
                "f2d748c5.d92da8",
                "936bc33f.bcd27",
                "97ab65f2.1a0728"
        "id": "f98f22cc.807ba",
        "type": "http response",
        "name": "",
        "statusCode": "",
        "headers": {
            "OK!": ""
        "x": 1290,
        "y": 140,
        "wires": []
        "id": "557d7766.022168",
        "type": "change",
        "name": "Barometer",
        "rules": [
                "t": "move",
                "p": "payload.kff1270",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\phone\\barometer",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 731,
        "y": 403,
        "wires": [
                "536ae3f0.1980dc",
                "5ef6a21e.75ce4c"
        "id": "3b30fefa.3f9012",
        "type": "ui_gauge",
        "name": "",
        "group": "9b558fbc.438aa",
        "order": 1,
        "width": "6",
        "height": "6",
        "gtype": "gage",
        "title": "RPM",
        "label": "RPM",
        "format": "{{value}}",
        "min": 0,
        "max": "7000",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1061,
        "y": 443,
        "wires": []
        "id": "33d571b3.db242e",
        "type": "change",
        "name": "RPM",
        "rules": [
                "t": "move",
                "p": "payload.kc",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\rpm",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 721,
        "y": 443,
        "wires": [
                "3b30fefa.3f9012",
                "5ef6a21e.75ce4c"
        "id": "69b56cf.77bc694",
        "type": "change",
        "name": "Mass Air Flow Rate",
        "rules": [
                "t": "move",
                "p": "payload.k10",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\mafrate",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 761,
        "y": 483,
        "wires": [
                "7ee21162.28cdb",
                "5ef6a21e.75ce4c"
        "id": "683933fa.d76f1c",
        "type": "change",
        "name": "Throttle Position",
        "rules": [
                "t": "move",
                "p": "payload.k11",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\throttle",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 751,
        "y": 523,
        "wires": [
                "3765c6b.fb70f3a",
                "5ef6a21e.75ce4c"
        "id": "ab2ff853.e8b808",
        "type": "change",
        "name": "Coolant Temp",
        "rules": [
                "t": "move",
                "p": "payload.k5",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\coolant",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 741,
        "y": 563,
        "wires": [
                "258b6f62.e82ab"
        "id": "c005b8b1.f06b98",
        "type": "change",
        "name": "Volage",
        "rules": [
                "t": "move",
                "p": "payload.kff1238",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\obd\\voltage",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 721,
        "y": 603,
        "wires": [
                "5b8bdb33.d96134",
                "5ef6a21e.75ce4c"
        "id": "96abaa53.c70988",
        "type": "change",
        "name": "Vacuum",
        "rules": [
                "t": "move",
                "p": "payload.kff1202",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\vacuum",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 731,
        "y": 643,
        "wires": [
                "913a6311.540cd",
                "5ef6a21e.75ce4c"
        "id": "3765c6b.fb70f3a",
        "type": "ui_gauge",
        "name": "",
        "order": 2,
        "width": "3",
        "height": "3",
        "gtype": "donut",
        "title": "Throttle Position",
        "label": "%",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1091,
        "y": 523,
        "wires": []
        "id": "ee5bc723.594bf8",
        "type": "change",
        "name": "Speed",
        "rules": [
                "t": "move",
                "p": "payload.kd",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\speed",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 721,
        "y": 683,
        "wires": [
                "c3863c64.b8c2d",
                "5ef6a21e.75ce4c"
        "id": "c3863c64.b8c2d",
        "type": "ui_gauge",
        "name": "",
        "group": "ea9cdc42.4bbc8",
        "order": 0,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "Speed",
        "label": "MPH",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1061,
        "y": 683,
        "wires": []
        "id": "7ee21162.28cdb",
        "type": "ui_gauge",
        "name": "",
        "order": 3,
        "width": "2",
        "height": "3",
        "gtype": "wave",
        "title": "Mass Air Flow",
        "label": "g/s",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1091,
        "y": 483,
        "wires": []
        "id": "536ae3f0.1980dc",
        "type": "ui_gauge",
        "name": "",
        "group": "26a930d9.ff8c",
        "order": 0,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "Barometer",
        "label": "units",
        "min": "800",
        "max": "1100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1071,
        "y": 403,
        "wires": []
        "id": "dfdc4763.7a8fd8",
        "type": "change",
        "name": "Speed GPS",
        "rules": [
                "t": "move",
                "p": "payload.kff1001",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\phone\\speed",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 741,
        "y": 723,
        "wires": [
                "535662ad.f1628c",
                "5ef6a21e.75ce4c"
        "id": "535662ad.f1628c",
        "type": "ui_gauge",
        "name": "",
        "order": 0,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "Speed GPS",
        "label": "MPH",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1081,
        "y": 723,
        "wires": []
        "id": "5b8bdb33.d96134",
        "type": "ui_gauge",
        "name": "",
        "order": 0,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "Voltage",
        "label": "V",
        "min": "9",
        "max": "15",
        "colors": [
            "#ff0000",
            "#008000",
            "#ff0000"
        "seg1": "13",
        "seg2": "14.3",
        "x": 1071,
        "y": 603,
        "wires": []
        "id": "b0123228.4a063",
        "type": "ui_gauge",
        "name": "",
        "order": 5,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "Coolant Temp",
        "label": "F",
        "min": 0,
        "max": "250",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1081,
        "y": 563,
        "wires": []
        "id": "913a6311.540cd",
        "type": "ui_gauge",
        "name": "",
        "order": 6,
        "width": "3",
        "height": "3",
        "gtype": "donut",
        "title": "Vacuum",
        "label": "",
        "min": "-20",
        "max": "0",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1071,
        "y": 643,
        "wires": []
        "id": "cee9fa09.98b6d8",
        "type": "json",
        "name": "",
        "pretty": false,
        "x": 751,
        "y": 198,
        "wires": [
                "3b9be5d8.84e04a"
        "id": "f2d748c5.d92da8",
        "type": "function",
        "name": "Parse Date",
        "func": "var date = parseInt(msg.payload.time);\n\nmsg.payload = new Date(date* 1).toLocaleString([], { hour12: true}).slice(0, 19).replace('T', ' ');\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 730,
        "y": 780,
        "wires": [
                "88bfc628.5727b8"
        "id": "88bfc628.5727b8",
        "type": "ui_text",
        "order": 1,
        "width": 0,
        "height": 0,
        "name": "Last Update",
        "label": "Updated",
        "format": "{{msg.payload}}",
        "layout": "row-spread",
        "x": 1070,
        "y": 780,
        "wires": []
        "id": "258b6f62.e82ab",
        "type": "function",
        "name": "CtoF",
        "func": "var tempc = msg.payload;\n    tempf = tempc * 9/5 + 32;\n    tempf = Math.round(tempf * 10) / 10;\n    msg.payload = tempf;\n    return msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 910,
        "y": 560,
        "wires": [
                "b0123228.4a063",
                "5ef6a21e.75ce4c"
        "id": "936bc33f.bcd27",
        "type": "change",
        "name": "IntakeTemp",
        "rules": [
                "t": "move",
                "p": "payload.kf",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\vehicle\\intake",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 730,
        "y": 840,
        "wires": [
                "a6732e91.735a9"
        "id": "ee354102.4a8d8",
        "type": "ui_gauge",
        "name": "",
        "order": 4,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "Intake Temp",
        "label": "F",
        "min": 0,
        "max": "250",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1070,
        "y": 840,
        "wires": []
        "id": "a6732e91.735a9",
        "type": "function",
        "name": "CtoF",
        "outputs": 1,
        "noerr": 0,
        "x": 899,
        "y": 837,
        "wires": [
                "ee354102.4a8d8",
                "5ef6a21e.75ce4c"
        "id": "3b9be5d8.84e04a",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "torque\\raw",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1034,
        "y": 202,
        "wires": [
                "5ef6a21e.75ce4c"
        "id": "5ef6a21e.75ce4c",
        "type": "mqtt out",
        "name": "",
        "topic": "",
        "qos": "0",
        "retain": "true",
        "broker": "fee1fac2.261a88",
        "x": 1292,
        "y": 193,
        "wires": []
        "id": "97ab65f2.1a0728",
        "type": "function",
        "name": "copy to json",
        "func": "msg.payload.json = JSON.stringify(msg.payload);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 770,
        "y": 100,
        "wires": [
                "72347975.0e2688"
        "id": "72347975.0e2688",
        "type": "function",
        "name": "Create query in topic",
        "func": "var out = \"INSERT INTO torque_json (timestamp,json)\"\nvar date = Number(msg.payload.time);\nout = out + \"VALUES ('\" + new Date(date* 1).toISOString().slice(0, 19).replace('T', ' ') + \"','\" \nout = out + String(msg.payload.json)  + \"');\"\n    \nmsg.topic=out;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 960,
        "y": 100,
        "wires": [
                "dba0040d.49d798"
        "id": "dba0040d.49d798",
        "type": "mysql",
        "mydb": "4cd2c8.ee368d38",
        "name": "",
        "x": 1300,
        "y": 100,
        "wires": [
        "id": "9b558fbc.438aa",
        "type": "ui_group",
        "z": "",
        "name": "Motor",
        "tab": "ac99e377.fdb83",
        "order": 1,
        "disp": true,
        "width": "9"
        "id": "ea9cdc42.4bbc8",
        "type": "ui_group",
        "z": "",
        "name": "Van",
        "order": 2,
        "disp": true,
        "width": "6"
        "id": "26a930d9.ff8c",
        "type": "ui_group",
        "z": "",
        "name": "Phone",
        "order": 3,
        "disp": true,
        "width": "6"
        "id": "fee1fac2.261a88",
        "type": "mqtt-broker",
        "z": "",
        "broker": "mqtt.YOUR.SERVER",
        "port": "1883",
        "clientid": "nodered",
        "usetls": false,
        "compatmode": true,
        "keepalive": "60",
        "cleansession": true,
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": ""
        "id": "4cd2c8.ee368d38",
        "type": "MySQLdatabase",
        "z": "",
        "host": "drobo5n.YOUR.SERVER",
        "port": "3306",
        "db": "openhab",
        "tz": "CST"
        "id": "ac99e377.fdb83",
        "type": "ui_tab",
        "z": "",
        "name": "Torque",
        "icon": "fa-car",
        "order": 2
