TP-Link dimmer switch binding?
Thk Hilbrand for the good support over this binding. I’m currently experiencing a strange behaviour with an HS220 Dimmer.
  • When controlling the dimmer item from openhab, the dimmer value always return to 0 and the physical light stay closed
  • When starting the light manually (app of physical wall dimmer) the Value gets updated in openhab and I can Slide around in openhab without any issue (except if I slide it back to 0)
  • If I close the light manually (app of physical wall dimmer) the Value gets updated to 0 and same behavior, can’t restart it in openhab.
I’ve been trying to search around in the forum but aside from this post nothing showed up
My event log is pretty much the same thing
2020-12-30 19:37:32.186 [ome.event.ItemCommandEvent] - Item ‘lt_ss_mur’ received command 35
2020-12-30 19:37:32.198 [nt.ItemStatePredictedEvent] - lt_ss_mur predicted to become 35
2020-12-30 19:37:32.201 [vent.ItemStateChangedEvent] - lt_ss_mur changed from 0 to 35
2020-12-30 19:37:32.338 [vent.ItemStateChangedEvent] - lt_ss_mur changed from 35 to 0
I did delete my thing in paper UI and Manually add it back
Details:
Binding:
TP-Link Smart Home Binding (Beta) market:binding-3614612 - 1.0
Device (Remove identification info):
device name Wi-Fi Smart Dimmer
feature TIM
hardware version 2.0
model HS220(US)
sofware version 1.0.5 Build 201211 Rel.085320
type IOT.SMARTPLUGSWITCH
