TP-Link HS110 item definitions problem
I have problem with TP-Link HS110 manual (default.items) item definition. According to available tutorial I defined it like this:
Switch HS110_switch “HS110 Switch” { chanel=“tplinksmarthome:hs110:955462:switch” }
where chanel value was taken from Paper UI Configuration - Things.
The problem is that I can not manage switch from Basic UI. Also other channels (rssi, energyUsage etc.) are not received.
Where I did a mistake ??
Aaaargh … typo !!! Should be “chaNNel” .
